Trying to diagnose a noise problem on a machine with an A06B-6052-H002 spindle drive and A06B-1003-B100-R motor. Motor sounds rough, worse at higher speeds. Spindle belt removed.
Disconnecting CN2 while motor was running, putting the motor into a coast, eliminated all noise. So thinking not bearing noise.
Put scope on PA and PB at the drive (A16B-1100-0080 top board), verified against the maintenance manual. Adjusted magnetic pickup till signals look good, no difference in the sound of the motor.
Any ideas what to do next? The maintenance manual I'm looking at does not mention any potentiometer adjustments to deal with noise (gain adjustment, etc.). As a matter of fact it doesn't provide info on a lot of the pots.
One more thing, motor Megs 1.5 Meg so there a chance it's got winding problems. Lead to lead is pretty consistant 0.34 ohm.
Thanks!
Alex
