586,069 active members*
3,455 visitors online*
Thread: BT30 Spindle
Page 2 of 29 123412
Results 21 to 40 of 570
  1. #21
    15362
    Re: BT30 Spindle
    Quote Originally Posted by Azalin View Post
    @mactec54 Thanks for the drawings. It'll be nice if you have some pics for the completed parts.
    This is of the small spindle, it does not matter how big the same style needs to be similar design, to be effective, this has the added slinger on the front for even more protection
    Mactec54
  2. #22
    Mar 2014
    1131
    Re: BT30 Spindle
    Thank you, I'm appreciated. I'm not a machinist but as a software developer I'm trying to understand how this seal works. If I'm not wrong oil/grease tries to get inside between the two part and this prevent the leak. Here the very stupid question comes. What if the room inside the labyrinth is full then what happens?
  3. #23
    15362
    Re: BT30 Spindle
    It is almost always clear, most machining centers, have an positive air pressure flowing through the labyrinth seal so they are not going to have grease or oil in them, a labyrinth is only to stop stuff getting inside, grease or oil if there is to much in the spindle bearings, it would slowly find it's way out, a spindle with oil mist, it will exit the spindle through the Labyrinth seal
    The second piece in the photo where you have the arrow is not always needed, this just an add another element of protection, this can be recessed into a thicker Endcap also
    This photo without the added piece inside, your spindle would fit inside where this piece was, with the labyrinth against the spindle shoulder then your bearing stack behind it
    Mactec54
  4. #24
    Mar 2014
    1131
    Re: BT30 Spindle
    OK that's very clear. I thought the seal was to prevent the oil leak. Thanks.
  5. #25
    15362
    Re: BT30 Spindle
    Azalin
    Here is a better break down of the photo parts
    Attached Thumbnails Attached Thumbnails Spindle Labyrinth Part-Inside End Cap.PNG   Spindle Labyrinth Part for Spindle.PNG   Spindle Labyrinth Part Assembley.jpg
    Mactec54
  6. #26
    Mar 2014
    1131
    Re: BT30 Spindle
    The lathe is too small to drill a 250mm part but I managed it.
    Sent from my GT-I9300 using Tapatalk
  7. #27
    Mar 2014
    1131
    Re: BT30 Spindle
    The cone has been cut.
    I dropped my cell phone and it seems the camera is damaged.
  8. #28
    Sep 2008
    86
    Re: BT30 Spindle
    How does it fit? Did you blue it to check? Looking good!
  9. #29
    Mar 2004
    1306
    Re: BT30 Spindle
    Nice work Suat
    Regards,
    Mark
  10. #30
    Mar 2014
    1131
    Re: BT30 Spindle
    Thanks Mark.
    @ebrewste it is a perfect fit.
    I think the shaft will be ready this week and ready for hardening next week.
  11. #31
    Mar 2014
    1131
    Re: BT30 Spindle
    I'd like to as for your opinion about pulley. What is the best pulley for this spindle? Teeth count and teeth module/pitch etc.
    Thanks.
    Edit: Actually I'll use a high speed motor and will need a big pulley in order to get a 2:1 gear ratio to decrease the spindle speed. So forget about the teeth count question.
  12. #32
    Mar 2004
    1306
    Re: BT30 Spindle
    Poly-Vee runs quietest. Or do you need a toothed belt for rigid tapping?
    Regards,
    Mark
  13. #33
    Mar 2014
    1131
    Re: BT30 Spindle
    Yes toothed pulley.
  14. #34
    Mar 2014
    1131
    Re: BT30 Spindle
    Small update. I purchased 48 teeth module5 25mm width pulley for the spindle and 25 teeth module5 25 width for the motor.
  15. #35
    Mar 2014
    1131
    Re: BT30 Spindle
    How much run-out is acceptable in the cone?
  16. #36
    Sep 2008
    86
    Re: BT30 Spindle
    10 um or so would be the upper limit in my mind. Lower if you plan on using small tools.
    Runout Versus Tool Life - CNCCookbook CNCCookbook
    Don't forget you can grind the spindle when it is installed in the machine. Most people say this is not a DIY activity, but neither is making your own spindle, so you should try it
    https://www.youtube.com/watch?v=X4yZKfK6hc0
  17. #37
    Aug 2008
    1186
    Re: BT30 Spindle
    That is awesome!!!!! I would definitely go for something like that, I bet it makes a huge difference on part finish and holding tolerance as the video stated!
    Sent from my XT1080 using Tapatalk
  18. #38
    Mar 2014
    1131
    Re: BT30 Spindle
    Thanks ebrewste.
  19. #39
    Mar 2014
    1131
    Re: BT30 Spindle
    Just received the pulleys. The big one is slightly damaged but It's not a big problem.
  20. #40
    Mar 2014
    1131
    Re: BT30 Spindle
    I've upgraded to Windows 10 however Solidworks won't work properly with that OS so I can't change the design. So I drew a quick labyrinth and want to ask for your opinion. Very simple and probably stupid design but my intention is to keep it simple however I don't want to build something useless so I value your opinions.
Page 2 of 29 123412
  1. Bt30 or bt40 spindle
    By KKamel in forum Spindles / VFD
    Last Post: 12-14-2015, 10:03 PM
  2. BT30 Spindle Help
    By Momentz in forum Benchtop Machines
    Last Post: 11-03-2015, 01:08 AM
  3. Looking for a BT30 Spindle
    By xtwalt in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2012, 10:10 PM
  4. BT30 Spindle
    By dirtridn2010 in forum Tormach Personal CNC Mill
    Last Post: 05-07-2012, 11:19 AM
  5. Reasonably priced BT30 ATC spindle.
    By dwalsh62 in forum News Announcements
    Last Post: 05-12-2011, 05:59 PM
