586,069 active members*
3,307 visitors online*
Thread: BT30 Spindle
Page 1 of 29 12311
Results 1 to 20 of 570
    Mar 2014
    1131
    BT30 Spindle
    Continuing from this thread
    Special thanks to @andypugh for his help and assistance.
    I already made the gripper and currently I'm modelling for the rest. I'll add the detail later but if any of you have a question, suggestion, feedback, comment or anything. Just ask away
    Here I am at the moment:
    And the gripper:
    Mar 2014
    1131
    Re: BT30 Spindle
    The drawbar rod. Used 1.2080 (I guess) steel. Hardened, tempered and grounded.
    Mar 2014
    1131
    Re: BT30 Spindle
    Here are some details.
    - Lower bearings will be 2x 7009 (A or C) angular contact ball bearing. It is 45x75x16mm
    - On the upper side I'll use one (or 2) 6008 deep groove ball bearing
    - The belleville washers are D2010211. I'm using parallel groups of 3, 24 in total.
    - Gripping force is 3kN and opening force is 5kN (more or less).
    - Needed stroke is 4.2mm but I'll have about 6mm in total.
    - Petals are C45 steel.
    Mar 2014
    1131
    Re: BT30 Spindle
    50x250mm 2080 steel for the main shaft.
    Mar 2014
    1131
    Re: BT30 Spindle
    If I'm not mistaken there are 3 type AC bearings with different contact angles. C (15°), A (25°) and B (40°). People ruse A or C bearings but I've never seen anybody used B. Which one would you recommend? I guess B is best if I want minimum play but since the B has a wide contact surface it is also the worst because it'll produce more heat.
    Feb 2013
    164
    Re: BT30 Spindle
    50mm seems a bit small for the spindle nose. Have you thought about your dog configuration? I'm attempting to replace an r8 spindle shaft with a bt30 one and had a similar problem. Here's the spec I referenced:
    http://i200.photobucket.com/albums/a...ine-taper5.jpg
    Sent from my SM-G920V using Tapatalk
    Mar 2014
    1131
    Re: BT30 Spindle
    Not possible with my baby lathe Thanks.
    Sent from my GT-I9300 using Tapatalk
    Mar 2014
    1131
    Re: BT30 Spindle
    Little changes on the design.
    Nov 2012
    29
    Re: BT30 Spindle
    Do you really need 4 bearings on front end? What stiffness are you planning?
    Mar 2014
    1131
    Re: BT30 Spindle
    The 2 in the middle are just sleeve. Others are bearings. Its hard to tell from the pic tho. Should have colored them.
    Oct 2012
    342
    Re: BT30 Spindle
    Here are some pictures of the BT30 spindle I bought from Aliexpress for reference. Hopefully they will be helpful.
    Attachment 303308Attachment 303310Attachment 303312
    Attachment 303306
    The two bearings on the left are pressed up against a shoulder and then a inner race from a bearing is used as a spacer. Then comes the timing belt pulley and nut that holds the pulley on. The two left bearings are sealed. The angular contact bearings on the right are not sealed. They are configured like yours but only one spacer. Further to the right is the labyrinth seal and the nose piece that clamps the outer race of the angular contact bearings against the housing.
    Attachment 303316 Attachment 303322Attachment 303320
    Here is the nose of the spindle shaft. The first picture shows the grooves that make up the most outside part of the labyrinth seal. Then the lighter colored aluminum ring is part of the labyrinth, it has a standing ring (going up in this picture) into an undercut in the steel of the spindle shaft above it. The second picture shows the nose ring, this is what clamps the outside race of the AC bearings. This is where some crummy work was done on my spindle, the aluminum tape you see was used to make up for parts being machined wrong. Where that aluminum tape is the aluminum ring from the previous picture is to be a press fit into. Someone machined the bore of the nose ring too big so they added a couple pieces of aluminum foil tape to bring it back to a press fit. The brown in the bottom of the nose ring bore is coolant and grease that has dried inside.
    -Dan
    Mar 2004
    1306
    Re: BT30 Spindle
    Nice work Suat. How are you doing the labryth seals on your design?
    Regards,
    Mark
    Regards,
    Mark
    Mar 2014
    1131
    Re: BT30 Spindle
    Dan, thanks for posting these. Before I decide to build my spindle I contacted a few ali express dealers and asked for some details about what they sell. Steel grade used on each part, belleville washers and force for opening and clamping, the bearings used etc. They all answered almost the same. "Setel bearings". Like I'm stupid. So I decided to build it myself.
    @Mark, I'm not there yet but I'm thinking to cut something like what Dan posted (see pic below) but also use a grease/oil seal. I'd like to take some recommendation here tho.
    15362
    Re: BT30 Spindle
    Azalin
    For a labyrinth seal design the Flange in your photo is a very poor design & offers almost zero protection for the Bearings, here are some cutaway designs,I have made, that work very well, a regular Seal is not suitable for that end of a spindle, they will get damaged from metal chips Etc
    These 2 Drawing will give you a better idea of what you need, to make for a labyrinth type seal, .1mm clearance is all that is needed on all faces where clearance is needed
    Mactec54
    Oct 2012
    342
    Quote Originally Posted by Azalin View Post
    Just to ensure that you are aware that flange is not the labyrinth seal. It is just provide the first channel which leads to the labyrinth seal. I think I have a nearly complete CAD model of my spindle, I will take a look tomorrow and create some screen shots of the cross section.
    Dan
    Mar 2014
    1131
    Re: BT30 Spindle
    @mactec54 Thanks for the drawings. It'll be nice if you have some pics for the completed parts.
    @engnerdan thanks
    Aug 2004
    780
    Re: BT30 Spindle
    Is there a cad model available ?
    Or one available elesewhere ..
    Mar 2014
    1131
    Re: BT30 Spindle
    Of what?
    Mar 2014
    1131
    Re: BT30 Spindle
    I have another question. I'll send the main shaft for nitriding. As far as I know a nitrided metal has minimum deformation so I'll leave very small amount of material on the outside the shaft for grinding. Question is should I leave material on the taper cone inside the shaft (for grinding) too? And is it necessary for tempering the shaft? I'm asking because the steel I use is high carbon and I want it as hard as possible.
    Oct 2012
    342
    Re: BT30 Spindle
    Here you go, first picture is a cross section of the entire spindle cartridge minus a few parts that don't mater to this discussion.
    Attachment 303648 Click image for larger version.
Name:	Whole Spindle Cross section2.jpg
    And a close up of the upper left corner of the previous picture. The red part is the labyrinth seal that is a press fit in the front retaining plate (blue).
Name:	Close up cross section.jpg
ID:	303650 Click image for larger version.
Name:	Close up cross section2.jpg
    -Dan
Page 1 of 29 12311
  1. Bt30 or bt40 spindle
    By KKamel in forum Spindles / VFD
    Last Post: 12-14-2015, 10:03 PM
  2. BT30 Spindle Help
    By Momentz in forum Benchtop Machines
    Last Post: 11-03-2015, 01:08 AM
  3. Looking for a BT30 Spindle
    By xtwalt in forum Uncategorised MetalWorking Machines
    Last Post: 11-20-2012, 10:10 PM
  4. BT30 Spindle
    By dirtridn2010 in forum Tormach Personal CNC Mill
    Last Post: 05-07-2012, 11:19 AM
  5. Reasonably priced BT30 ATC spindle.
    By dwalsh62 in forum News Announcements
    Last Post: 05-12-2011, 05:59 PM
