Do anyone have explanation for errors :
PLC 9434 Machine in toling : tooling selector (SAT) active (in 2)
PLC 9007 Slot reset required
GMM 275 NC in emergency
machine in tooling means you left the key on after manually releasing your tool.
Slot reset required means that you need to do a slot reset and raise the head before the machine will do anything else.
NC in emergency means that you hit a stop somewhere and you need to "stop,reset,clear" your machine.
Good luck.
