586,100 active members*
3,239 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Help ID Higbee thread
    Jul 2007
    72
    I have made programs, on FANUC control machines, for external threads with blunt starts.
    Now I am running into issues of the tool not escaping fast enough to avoid clipping the following thread as it exits the cut.
    Here are 2 program examples I have attempted without success.
    ex.1 M22 chmfer off
    G71 X3.678 Z-2.98 I0 B0 D.009 H.09 F.0833 M32 M75 M22
    ex.2 M23 chamfer on
    G71 X3.678 Z-2.98 I0 B0 D.009 H.09 L.1 F.0833 M32 M75 M23
    Any suggestions are appreciated
    OSP700L control
    I'm just a butcher masquerading as a machinist
    Feb 2005
    303
    Re: Help ID Higbee thread
    I've had great luck using a G34 move in Z, followed by another G34 with a very small (~.010") Z move and a large X move at the same feedrate (The Z is necessary so the control can apply the feedrate properly.)
    The only caveat is that the blunt start routine may need a slower RPM, because the acceleration curve of the X-axis drive may be such that is does not achieve full speed until it is already clear of the part.
    I'm currently getting a 1" long (1" along the circumference) blunt start on a 6" diameter thread; threading cycle is at 175 RPM, blunt start is at 125 RPM.
    Apr 2009
    1262
    It looks to me like you need to change your B value in order to accomplish this with the G71 cycle. B0 effectively turns off any chamfering since there is no angle of chamfer.
    Ghyman's suggestions should also work.
    Best regards,
  1. Anyone know how to program a higbee using x instead of z
    By BOATDUDEGUY in forum Material Machining Solutions
    Last Post: 11-21-2013, 12:22 AM
  2. clipping/blunting/higbee thread question
    By jgarner77 in forum G-Code Programing
    Last Post: 09-13-2012, 07:31 PM
  3. Higbee Thread
    By gene rhodes in forum FeatureCAM CAD/CAM
    Last Post: 02-26-2011, 06:17 AM
  4. How to program a Higbee thread cut?
    By Driftwood in forum G-Code Programing
    Last Post: 02-01-2010, 06:36 PM
