586,396 active members*
2,975 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > How to make custom threads
Results 1 to 6 of 6
    May 2015
    25
    I have a job coming up were I have an OD and ID left hand thread M6.5x.5mm. Now I cant find any info for this thread existing only a M6x1.mm in the machinist handbook. I know this thread can be produced but how do you go about finding out your thread specs? Do you just use your Major Diameter for a M6 and program the machine to turn to the .5 pitch?
    Feb 2005
    303
    Re: How to make custom threads
    With very few (if any) exceptions, Left-hand threads are identical dimensionally to the same Right-hand thread.
    Whatever dimensions a right-handed thread has will be the same for the left-handed thread.
    ==edit==
    sorry, I missed the intent of the question.
    M6 x .5 will follow the same rule of thumb as other threads for internal threads -
    6mm(OD) - 0.5mm (pitch) = 5.5mm tap drill.
    Here is a good reference.
    May 2008
    667
    Is this M6.5 X .5 or M6 X .5?
    Jeff
    Feb 2005
    303
    Wow, I'm sorry.
    Maybe I should read the question before answering!
    First of all, check out the picture here for some good direction; I believe this image is also in the Machinery's Handbook.
    Running through the calculations for 6.5 x 0.5, I get:
    External
    Major Dia = 6.446
    Minor Dia = 5.905
    Internal
    Major Diameter = 6.500
    Minor Diameter = 5.959
    Sorry it took me 3 tries to get it right :/
    </hangs head>
    May 2015
    25
    Its 6.5 x .5 threads. We so a lot of machine work for the medical industry so everything is oddball.
    Oct 2007
    88
    ii think i have turned that thread a few years ago. I believe the print called out Major, Minor, and Pitch Ø. We were given 2 sets of thread rings from the customer for pitch, but operators didn't check the minor well enough.
  1. how to make NPT threads in Mazatrol Matrix
    By klzz in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-11-2022, 11:54 AM
  2. How do you make different H-Class threads with a thread mill.
    By jsclark in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-28-2014, 09:42 AM
  3. How to make acme threads?
    By MPI-Ferrari in forum CamWorks
    Last Post: 08-21-2012, 07:59 PM
  4. How do I make threads on my Sieg C4?
    By Blakelidge in forum Mini Lathe
    Last Post: 07-30-2011, 06:52 PM
