Originally Posted by
OkumaWiz
There are 2 prox switched on the back of your actuator that need to be adjusted so that only one of them is on at a time. One is for unclamp and one for clamp. In the event that your chuck over travels, the alarm occurs. You will probably need to unclamp and reclamp in order to start running the spindle again.
BTW, you should still be clamping on something in order to bore your jaws correctly and you should stay in the middle of your stroke as shown on your master jaw #1 markings in order to maintain good gripping pressure. You may need to bore at a reduced pressure and then return to your normal pressure once bored.
Another possibility is to use the M185 Chuck Rotation Interlock OFF if your machine has the option.
Best regards,
