586,112 active members*
3,201 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Alarm 102 Servos off & 157 Mocon Watchdog
    Jan 2016
    Hi everyone
    We have a 2002 HAAS VF2. Since we purchased it last June we have run it no more than six times and it ran well. Yesterday I ran a fly cut program on it and once the program had finished and the axis returned home, Alarm 157 appeared and will not clear. I've checked inside the cabinet and there are no orange LEDs and all the red LEDs are lit including the green pass LED. I've checked all the connections on the MOCON board whilst wearing an anti-stat band and they all seem fine. Is there likely to be a simple solution or will I have to buy a new MOCON board. I'm guessing the 102 Servos off Alarm is due to the machine not being able to fire up because of the 157 Alarm.
    TG
    Sep 2006
    296
    Re: Alarm 102 Servos off & 157 Mocon Watchdog
    Probably need a new Mocon and yes the 102 pops up any time the servos are off such as in alarm state. Funny thing is i had one that threw up the same alarm, then i switched the mocon board with an older machine which doesnt have the Haas vector drive and the board works in the older machines. The old machines with Magnatek and Mitsubishi spindle drives control most of the spindle controls through the IO/PC board and not the mocon. Worth a try if you have any of the older models around.
    Jan 2016
    Hi
    Thanks for replying. I've had a look at the HAAS UK website and the boards are around £889 plus the engineer to fit (as it says Requires installation by an HFO). Getting a quote for an indy company to repair which they provide warranty for the whole board not just the part they fixed.
    Thanks again
    Apr 2012
    84
    TG001,
    If you're still having trouble finding a replacement board, let me know. There's a chance we might have one and can get it to you. We could also evaluate your board for repair if that's an option if you. Email me your part numbers at [email protected] and let me see what I can do.
    Tyler Hallowell - Account Manager
    International Electronic Solutions
    67 American Way Suite 140
    Dawsonville, GA 30534
    P: 855-437-3497 (x104)
    F: 706-344-1227
    E: [email protected]
    Industrial Electronic Repair & Servo Motor Repair | International Electronic Solutions
    We fix it all! Give us a call at 855-437-3497.
  1. pc500 watchdog alarm
    By TONYACC in forum Fanuc
    Last Post: 10-08-2019, 01:21 PM
  2. Replies: 2
    Last Post: 08-25-2015, 03:53 PM
  3. Low Voltage Alarm, Changed the Mocon Board
    By motorway in forum Haas Mills
    Last Post: 06-28-2013, 08:16 PM
  4. Alarm 157 Mocon Watchdog Fault on VF-0E
    By hoi.le in forum Haas Mills
    Last Post: 12-15-2011, 05:04 AM
  5. watchdog timer alarm on kryle vmc.
    By arpit in forum DNC Problems and Solutions
    Last Post: 09-12-2010, 03:50 PM
