586,389 active members*
3,289 visitors online*
Results 1 to 9 of 9
    May 2015
    5
    dxf2gcode small problem
    Hello,
    Gcode for part is ok.
    but where to set the tool diametre ? And where i can set tol position ?
    Theres are only few options to set.
    my cnc -
    May 2015
    5
    Re: dxf2gcode small problem
    (gcode runs whit no tool compensation).
    My tool (8mm cutter) should be out off part , now its going on centre :/
    Can help some one
    You probably need to do the offset in your .dxf file.
    May 2015
    5
    I have lot of drawings, it takes time to remake all of them. Is dxf2gcode program that god but dont have off set function ?
    I've never used it, but usually simple .dxf to g-code converters don't have any offset functions. They just convert the lines to g-code exactly as they were drawn.
    Sounds like you need a real CAM program.
    May 2015
    5
    thank you for help!
    the solution is to make offset in solidworks and remake gcode. (i will try it next monday on cnc whit mdf )
    But some times i plan to make 3d furniture, like dors whit wawes or lines somthing like that. So i have alphacam but mach3 drops a lot of bad lines in gcode and stop at first lines..
    i allways get this mesage, and canot try to simulate suting ?:/
    Apr 2015
    327
    Hello,
    for 3D engrawing you have to create user define tool.
    1. Create geometry define tool
    2. Goto Machine - Define tool - User defined.
    3. Select geometry which define tool
    Or select User tool which is in a default database after instalation .
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
    May 2015
    5
    thank you very much.
    still learning, but part as photo i was uploaded, it cut perfect.
    Deleting some lines in gcode, and it works perfectly. I will cut someting nice, and upload photo
    Jan 2009
    193
    You can define your own user tool or use the existing tools in the tools library of the software.
  1. DXF2GCODE FREE LIGHT CAM SOFTWARE
    By mpickell in forum Uncategorised CAM Discussion
    Last Post: 08-15-2015, 12:43 AM
  2. ooDraw, Inkscape and dxf2gcode conundrum
    By skiddaw in forum Uncategorised CAM Discussion
    Last Post: 12-09-2010, 08:12 AM
  3. DXF2GCODE freeware program
    By cwebs in forum G-Code Programing
    Last Post: 10-02-2009, 06:25 PM
  4. Hi and a small problem
    By davegt27 in forum Haas Mills
    Last Post: 07-04-2008, 03:57 AM
  5. DXF2GCODE it is free
    By plasmaplasma in forum Uncategorised CAM Discussion
    Last Post: 06-30-2007, 05:36 AM
