I am working on a Z axis for a small milling machine. Already have the X-Y part done has crossed roller rails and precision ground ball screws.
I have read through many threads on the zone about linear rails. It seems that the general best recommendation is 2 rails and 4 blocks for each axis.
I understand that 2 blocks per rail increases the load/moment carrying capacity.
I have some heavy duty 35mm profile rails, I know overkill but they were a good deal. The blocks are about 6 inches long. The Hiwin 25mm blocks(for another project) I have are about 3 inches long.
Based on the size of the 35 blocks and rails I am thinking I might be ok with only 2 rails and 1 block per rail since the contact area would actually be larger than 2-25mm blocks on 1 rail. I will no where near approach the load rating of the 35mm blocks/rails.
I understand the idea behind 2 blocks per rail is to spread them apart by a specific ratio (1.6:1 or more) so the support the load better, but many projects I see don't space the 2 blocks per rail far apart at all because it takes up too much travel space and so really don't gain much then other than just increased load capacity with 2 blocks(at least how I see it).
Just want to see if I am missing some other criteria that would require the 4 blocks, even with the 5+ inches of contact from the 35mm blocks.
Any thoughts would be appreciated.
Chris
