586,075 active members*
3,886 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Compatible Sanyodenki servo AC and amplifiers
Results 1 to 10 of 10
    Dec 2015
    7
    Question Compatible Sanyodenki servo AC and amplifiers
    Dear All,
    First of all I have to say I am not an electrical engineer (I am a chemist) but I have to go thru this. My experience with motors is 3D printer and wiring 3 stepper motors running with Mach3.
    I have 2 servo motors 200AC, 100W and two amplifier. See photo. I want to use them for small cnc router.
    My questions are:
    1. Are the motors and amplifiers compatible?
    If the answer of the question 1 is positive, so:
    2. What connector should I use and where to buy? I need wiring diagram. I found some in internet for other motors but probably they are similar.
    Thank you in advance.
    Dec 2015
    7
    Re: Compatible Sanyodenki servo AC and amplifiers
    Does anybody have an idea? :drowning:
    24221
    Is there no information on the SanyoDenki site.?
    The biggest decider with compatibility is in the form of commutation on motor and drive.
    Al.
    Albert E.
    Dec 2015
    7
    I could not find such information. I see the connectors don't match which dishearten me.
    If the amplifier and the motors are compatible I will try to find some experienced person to help. I just need general information and steps I have to do if I start the project.
    If they are not compatible I will postpone the project till I find motors.
    I really appreciate any help or advice.
    24221
    Either way you are going to need the drive setup information and motor details, Check to see if there is a SanyoDenki support contact it maybe with a distributor even.
    What are the model numbers of the drives and motors?
    Al.
    Albert E.
    Dec 2015
    7
    Two motors 100W 200AC, P50B04010DXS4E and P50B05010DXS20
    Two amplifiers 200AC model PV1A015SMT1P50
    Dec 2015
    7
    The answer of the representative of Sanyodenki:
    "Thank you for your inquiry, however I should inform you item you request is a customized one.
    Due to property reasons, I advise you to contact customer directly to get information.
    I thank you in advance for your understanding."
    Any suggestions?
    Oct 2005
    1145
    I have never been able to get anything usefull from Sanyo Denki. They are teh least helpfull of all teh other servo drive manfs. You will get teh same answer EVEN if you use a model number directly off the site to ask help for (;-) Been there done that.
    That said IF both units are sanyo there then is a good chance they will work together , just beware on most published spec sheets teh Hall order color code is WRONG. IF I rememebr correctly teh B and c are reversed. The only way to know for sure is to scope teh signals. Done that as well that is how we found out they were wrong.
    Good Luck, (;-) TP
    Dec 2015
    7
    So I have to find qualified engineer to do it professional. I thought The connectors would be compatible and just to connect them.
    Thank you vmax549 and Al.
    Oct 2005
    1145
    I would simply hook them up to published specs and see if it runs then work from there. IF you are not familar with AC servo drives it might be best to seek help from someone local that understands the process. Once you have seen it all done it is not that bad to do another one.
    (;-) TP
  1. Did I fry my servo amplifiers?
    By jderou in forum CNC Machine Related Electronics
    Last Post: 10-27-2014, 03:07 AM
  2. Fanuc Servo motors and servo amplifiers.
    By molma in forum For Sale Only
    Last Post: 09-07-2014, 11:05 PM
  3. sanyodenki servo amplifie model 65BA015VXKH0.
    By dtk2311 in forum Servo Motors / Drives
    Last Post: 05-28-2012, 03:49 AM
  4. sanyodenki servo nemicon encoder
    By cncfoam in forum Servo Motors / Drives
    Last Post: 06-17-2010, 02:54 AM
