586,105 active members*
3,313 visitors online*
IndustryArena Forum > CAM Software > Mastercam > need help with simple radial groove
Results 1 to 3 of 3
    Aug 2011
    121
    I have a plate in which I need to cut multiple radial grooves in. I would like to cut the groove helically in 1/8" increments down to 1/2" deep. This is probably extremely simple but I can't figure it out. I can get a plunge at each increment using the contour path and depth cuts. I also tried circle mill, but it wants to clean out the entire circle, not just the groove I want to create. The groove width is also the same width as the end mill I am using. I'm using X9, any help would be appreciated.
    Aug 2008
    121
    Re: need help with simple radial groove
    Quote Originally Posted by poster View Post
    If I am understanding correctly, this is cut similar to a "O ring groove" on the face of the plate ? If so you can use the "contour" tool path set contour type to ramp , set angle to what you want , turn lead in and lead out off. This will give a helical cut going down.
    Sep 2009
    93
    Sounds like contour with ramp (depth) will do it
    Not sure what u mean about helix
    Sent from my SM-G900V using Tapatalk
  1. RADIAL DRILLING ON OD
    By The Wolf! in forum Haas Lathes
    Last Post: 12-04-2013, 07:22 PM
  2. Replies: 2
    Last Post: 03-23-2013, 02:52 PM
  3. CNC Radial Engine
    By MMT in forum I.C. Engines
    Last Post: 04-27-2012, 05:56 PM
  4. Simple V groove late I cant figure out
    By DaOne in forum Mastercam
    Last Post: 02-26-2012, 02:58 AM
  5. Radial Groove
    By skmetal7 in forum PTC Pro/Manufacture
    Last Post: 04-04-2010, 02:01 PM
