Originally Posted by
ajclay
I've been trouble free for a very long time with my cnc plasma set-up until a few days ago.
I had a lost arc during a contour and had to restart the arc and program to finish the part. Changed the consumables, the others were used a good bit so I didn't give it any more thought.
A few days later I had a lost arc again. Restarted and cut a very short distance and lost arc again.
I noticed that the error lights on front of power unit are on. The "V" indicator is illuminated on the front of power unit when it happens. Stays on for 10 seconds or so and goes off.
It's getting worse because now it happens during pierce. The arc pierces about half way and goes out. I can manually start the torch and the same results. Stays on for a split second and arc stops.
I checked the line voltage and it seems to be OK. Manual says, High or Low voltage will cause the "v" light to come on.. I'm not seeing a voltage problem checking it with a fluke meter.....
3 phase and crossing between legs get 248.6v, 250.2v, 249.5v.
How should I trouble shoot this? I'm assuming it's not CPU related or other electronic hardware related, but you know what they say about assumptions......
Thanks for the in-put....
AJ
