586,655 active members*
2,839 visitors online*
    Oct 2015
    Post Chinese 4 axis router 4th axis configuration
    hi
    is there anyone that can help me. I have one of these chinese cnc routers that I bought of ebay. It came with a 4th axis lathe type chuck attachment. I have successfully used the 3 axis to machine several items, that i am quite pleased with. However I want to use the 4th axis chuck but am unable to get it to function. I use Mach 3 mill and also have Mach 3 turn programs which is run on a PC using windows XP, but cannot see how to configure the 4th axis to work. The 4th axis chuck has a separate wire that connects to an additional DIN type 5 pin socket on the Dongdadk control box. Any help to configure this 4th axis would be appreciated. I do not necessarily want it to turn continuously like a lathe, but to step round so that the Z and X axis can be used to cut a profile.
    Many thanks
    May 2015
    1422
    Re: Chinese 4 axis router 4th axis configuration
    Those things work in mill profiles, not lathe (to save you wasting time trying to get the lathe side going).
    Does the A axis appear in the main window alongside XYZ in the mill profile? Does it reset and try to go to zero in the DRO?
    Can you get the A axis moving in the MDI panel with a "g00 A300" command?
  1. Need Help with Chinese 4 axis cnc 6040 router.
    By urupeja in forum Machines running Mach Software
    Last Post: 12-16-2016, 10:43 PM
  2. Replies: 0
    Last Post: 04-28-2015, 02:27 PM
  3. X & Y axis configuration
    By Lovy in forum Mach Software (ArtSoft software)
    Last Post: 04-23-2012, 05:48 PM
  4. Replies: 1
    Last Post: 07-12-2010, 01:45 PM
  5. Need help with axis configuration
    By jetijs in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 08-24-2006, 11:06 AM
