586,103 active members*
3,372 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > 4th axis getting the best of me
    Trying to slot some flutes and can not for the life of me get the cutter to cut on the edge instead on the top.
    New to 4th axis and could use some help.
    I attached the g code that runs the bit on the bottom and the iges file.
    Any help would be appreciated
    Steve
    Feb 2009
    328
    Re: 4th axis getting the best of me
    I believe you are looking for this? Go to this page and select, mill machining/Operations for 4th axis and 5 axis milling/Rotary machining. Let me know if it works.
    SprutCAM 10 User Guide
    Apr 2017
    16
    Im having the same issue.. Have spent 6 hours on this and still no luck. I can get the 4th axis to rotate using the transition mode (telling it how many degrees to turn) but thats its!
    Apr 2016
    44
    What operation are you using? Generally there is a tool orientation setting that needs to be set to fixed as opposed to base surface (don't quote me on the verbage as I'm away from the PC).
    Apr 2017
    16
    Thanks for your reply Philly..
    I have uninstalled and reinstalled and it now seems to work,
    It must have been some sort of software bug as i did exactly the same process after i reinstalled it and it worked. Im using windows 10 Pro 64bit.
    Cheers
    Shane
  1. Replies: 16
    Last Post: 09-11-2017, 10:31 PM
  2. Replies: 1
    Last Post: 11-17-2015, 07:37 PM
  3. Replies: 0
    Last Post: 08-04-2013, 05:30 AM
  4. 5-axis, 4-axis, and 3-axis CNC Router manufacturer
    By roctech in forum Roctech CNC Routers
    Last Post: 05-24-2012, 09:12 AM
  5. New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter
    By the__extreme in forum CNC Wood Router Project Log
    Last Post: 02-26-2007, 09:58 PM
