586,112 active members*
2,999 visitors online*
    Jan 2016
    5
    How do you place material on table safely
    Looking at possibly building a table. Would like to have your solutions on placing material on the table without damaging anything. The largest piece would be 6' x 12' x .75" about 2200 lbs.
    Would like to use a forklift but not sure how to lay on the table.
    Tim
    Aug 2010
    19
    Re: How do you place material on table safely
    I fixed/ran a torchmate 5x10, and even dealing with 1/4" plate full size, is a job.
    I used a forklift to get it up and over the "back end" and laid wood rails down
    to slide it down.
    Major pain to keep from dinging the ways. After a couple of times I could see
    where an accident will occur.
    Buy the HarborFreight gantry crane at $700, it will do just what you need,
    carefully and fully controlled "flying it in" and down onto the table surface.
    Sep 2011
    102
    We use an overhead jib crane with a spreader bar and magnets. It works very well. You could also use your forklift in the place of an overhead crane and just hang the piece of steel from your forks with a spreader bar and magnets.
    Jan 2016
    5
    Thanks Guys
    I think we will have to use the magnets and spreader bar to do it safely. The magnets while pricey are not as expensive as I thought.
    Feb 2006
    1260
    I bolted a couple "standards" on the back side of my table. to help align plate parallel.. Carry plate in with fork lift I always leave apx 1' of plate extend beyond fork tips...... once carried over table lower & tip out till edge of plate makes contact with slats Then back out. Plate will slide down forks as you back out lowering second edge to the slats without any banging around. I Handle & place 4' X 12' A 1" A36 this way also 1 1/2" X 4' X 8' sheets.
    If it works.....Don't fix it!
  1. hot table to glue material to table
    By tommy78 in forum Uncategorised WoodWorking Machines
    Last Post: 09-05-2014, 07:26 AM
  2. table material idea
    By ashb82 in forum DIY CNC Router Table Machines
    Last Post: 10-15-2013, 08:02 PM
  3. Best Material for Dedicated fixtures to place on vacuum grid
    By 777funk in forum Work Fixtures / Hold-Down Solutions
    Last Post: 10-27-2010, 04:15 AM
  4. Where is a good place to buy parts for CNC Router table?
    By JB Laser Tech in forum Want To Buy...Need help!
    Last Post: 08-10-2009, 04:50 PM
  5. Good place in US to buy vacuum table for laser.
    By jinu117 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 12-13-2007, 08:47 AM
