586,060 active members*
4,569 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Gerber > Speed control on Gerber Advantage Router 600
    Jan 2016
    Hi all,
    I'm having a problem with my AR600 that is currently making it unusable. I've narrowed down the issue to a problem with the spindle speed control. Previously, I would adjust the dial to change the spindle speed. The display would show the speed in RPMs (dropping the final digit, so if I was setting it at 10,000 rpm for plywood it would show as 1,000). At some point however the speed control seems to have reset or been changed, and now shows a frequency reading instead, going from 0-60. If I try and operate the machine it will trace the correct path, but the spindle will spin incredibly slowly, eventually shutting itself off due to a fault. I've reached out to Gerber, but the machine is no longer supported so I'm not getting any help there. I've poured over every manual I have on hand, but can't find what setting possibly could have been changed or how. I'm worried that it had some special setting coming from the factory that has since been wiped.
    If it helps, here's the details on what I'm running:
    Saftronics G3+ motor control
    Yaskawa JVOP-100 digital operator
    Gerber Omega Artpath software
    This is the first shop I've been in charge of that has had a CNC router, and I'm pretty much entirely self-taught in operating it, etc. Thanks in advance for any help and/or advice. And feel free to let me know if this isn't the forum I should be posting this in.
    Thanks again,
    Neil
    Re: Speed control on Gerber Advantage Router 600
    Hola mi estimado amigo, he visto ese tipo de router y muchos problemas de ellos. lo primero que usted debe hacer es revisar el potenciómetro de control del box. Este debe de administrar voltaje adecuado para que gire mas rapido o mas lento , puede que se halla dañado y debe de reemplazarse. revise usted que este funcionando correctamente.
    También debes revisar la configuración de variador de voltaje Saftronics CIMR-P5U25P5 Unidad de CA GP5-25P5, P5U25P5, JVOP - 131U Yaskawa- Revisar que los parámetros de configuración de variador son los corrector, pueden haberse cambiado recuerda que el variador le va a dar la velocidad de giro del motor. También debes ver si tienes códigos de error en el variador de voltaje para saber si hay algun daño en el variador de voltaje.
    por último debes de revisar las fases del motor.
    saludos
    Walter
  1. Advantage 600 by Gerber
    By Claude Boudreau in forum Commercial CNC Wood Routers
    Last Post: 09-12-2015, 12:35 AM
  2. HELP! Anybody have a Gerber Advantage 400 (AR400) CNC router?
    By brian butler in forum USA Club House
    Last Post: 05-18-2014, 04:53 AM
  3. Router Speed Control
    By Seamazter in forum CNC Machine Related Electronics
    Last Post: 10-27-2010, 08:47 PM
  4. Router speed control
    By dwacker in forum DIY CNC Router Table Machines
    Last Post: 05-21-2007, 08:10 PM
  5. Router speed control
    By ljoe1969 in forum CNC Machine Related Electronics
    Last Post: 08-01-2005, 02:13 PM
