586,103 active members*
3,382 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Lathe - long thread accuracy
    Jan 2008
    8
    In reality, to what accuracy can lathes commonly keep a long thread pitch length?
    We have a 'dumbbell' shaped component - 28" long with a 5" long, 1 1/4" dia. 11tpi thread on each end.
    The threads must be 'in pitch' - the same thread - like a piece of studded rod with the mid section turned down.
    We need the pitch over the 28" to be within 0.002" but the CNC guys with have contacted say they would struggle to produce that accuracy?
    Cheers, Sean
    Dec 2007
    29
    Quote Originally Posted by cdspk View Post
    Cheers, Sean
    Yeah that's a long thread if machine has feedback scales it could be very possible...
    Mar 2016
    7
    Re: Lathe - long thread accuracy
    Hi, new here, long time on manual machines. Hope to start playing with CNC.
    Your project sounds pretty straight forward on a manual machine (put the follower rest on and away you go). I recently completed a lead screw for an antique meat slicer: 15.75" thread, 3/4-10. You would laugh at me for how long it took, but my pitch diameter was within the tolerance you have requested, with a much more flexable set up.
    I assume you will need tailstock support. With CNC, could you not simply cut it as a straight thread, then measure the thread - determine how much tool push there is, then tell it to cut that much of a taper in the thread?
    May 2013
    480
    is the material aluminum or steel?
    on the surface it sounds easy, 2 thousanths is the same as 2 tenths at 2.8 inches.. but you will probably need to make one piece.. measure it, and then adjust the machine, or the code to produce the next one correctly...
  1. M115 x 10 mm thread 1200 mm long
    By mattlynx in forum Uncategorised MetalWorking Machines
    Last Post: 12-09-2013, 09:02 PM
  2. Cutting Long Metric Thread
    By stuby in forum MetalWork Discussion
    Last Post: 08-30-2011, 05:30 PM
  3. Thread Milling and accuracy of arc centers
    By jmcglynn in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 01-15-2009, 07:38 AM
  4. Old big long thread on UHU servo controller.
    By vroemm in forum UHU Servo Controllers
    Last Post: 06-30-2008, 08:21 AM
  5. thread outlining ballscrew/rails/accuracy etc?
    By blau_schuh in forum DIY CNC Router Table Machines
    Last Post: 12-30-2006, 07:44 PM
