I recently got to but a 2004 Epilog Mini from a friend. The machine was sold as a project and the owner had bought it from a person who had started to modify it for being used as a small router (?)
I have all of the original parts but two mirrors (x and y-axel)
The laser was said to fire last time the machine was used, but I doubt it - its dead!
I is equipped with a Coherent 35W module and I have opened the RF section to se if anything was obvious. The only thing I could see was a cracked solder joint on the output from the balun after the BLF278 transistor. The was still contact but I resoldered - unfortunately to no use-it still wont fire!
Quote for a repair was ~$1500 to steep as I only planed to use the machine for prototyping.
So I'm faced with two option (I think)
1. Replace the RF transistors in the laser module and hope that this will fix the problem - cost ~$250
I have no clue if it has been restored before and the marking on the module is from 2004 - so most likely it's "original"
2. Replace the laser module with a smaller diode version
My goal is to be able to engrave black anodised aluminium as I make watch dials in this material in my small CNC router - but the finest lines are 0.1mm wide as this is the smallest router bits available (and they would break if they were smaller).
If I replace the CO2-module with say a 2-3W 445nm blue laser, would this be doable?
Can I place the diode laser on the Y-axis and use the original mirror/lens assy ?
Sorry for all the noob questions but I have been Googling for information for a week but not found any information if this can be done!
/Roger
