586,058 active members*
3,534 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > plasma cutting using Milling machine controller
    Jan 2016
    In plasma cutting application ,if sheet is bend, we have to change plasma torch height accordingly during cutting process.
    The torch is located on Z axis. So I need the function to up & down torch by pressing Z+ & Z- key manually (JOG mode) at the same time with controlling X & Y axis by MEM mode. My controller currently can not perform this task. Is there anyone can give me suggestion for this case?
    Jul 2005
    2415
    Re: plasma cutting using Milling machine controller
    Are you using MACH3 ?
    Jan 2007
    599
    You should get Torch Height Control, it will do it automatically (as long as you buy a good control.....)
    Jul 2005
    2415
    Most controllers/control programs do not allow external jog of an axis while code is running. MACH3 has that provision and you can use the keyboard or an actual external THC to do it automatically. Otherwise you need a full Stand Alone THC with its own control, motor , IHS and settings. I am sure LINUXCNC has some form of external jog option but we have not found it so far! It WILL take UP and DOWN signals from a THC via the parallel port HAL so faking it with a swtich would be trivial
    TOMcaudle
    Home
  1. Replies: 1
    Last Post: 06-16-2014, 08:15 AM
  2. Replies: 0
    Last Post: 04-28-2014, 09:44 AM
  3. Replies: 0
    Last Post: 04-17-2013, 07:09 AM
