586,913 active members*
3,120 visitors online*
    Jan 2016
    MACH3 SPINDLE CONTROL - CONTROL BOARD HELP
    Hi All,
    I wanted to post this issue that I am having with setting up Mach3 to control spindle speed, I have watched and read a lot of instructional information on Youtube and Google search but still with no luck.
    A brief over view of what i have done is tick a few boxes and put a couple of numbers in the spindle motor outputs and spindle setup - but was not confident in what I was doing and didnt want to choose the wrong pin port number and cause and issue's
    I noticed with one setup that there was a slight humming sound coming from the machine when the RPM SPINDLE CW F5 was turned on and the SRO% was moved upwards - so I pretty much stopped trying to do it and to look further into this.
    I thought best place is here as I have seen and read some pretty amazing and knowledgeable things.
    See below images with Pins And Ports for the Control Board and Mach3 etc
    Any help would be much appreciated - thanks
    Jan 2016
    Re: MACH3 SPINDLE CONTROL - CONTROL BOARD HELP
    Sorry all, I just noticed I have posted this in the wrong forum. I have posted in CNC Mill Software
  1. G0704 stock spindle control board to mach 3 via C32 board.
    By ballistic42 in forum Benchtop Machines
    Last Post: 09-22-2016, 02:47 AM
  2. Replies: 0
    Last Post: 11-30-2014, 05:16 AM
  3. Break out board with mach3 for temp control
    By BTS in forum CNC Machine Related Electronics
    Last Post: 11-13-2012, 07:05 PM
  4. Drive control board options for Mach3
    By CricutDude in forum Mach Software (ArtSoft software)
    Last Post: 03-21-2011, 10:10 PM
  5. Need Breakout board to control Mach3
    By Mongkol in forum CNC Machine Related Electronics
    Last Post: 04-19-2008, 06:38 PM
