I am retrofitting a vertical mill with a used Dynapath control. I need a control manual or the info on how to setup the parameters.
Examples:
Ball screw pitch
Encoder count
Axis lengths
Motor type
Reversal compensation
Axis position compensation
Note: I was a bear to wire and that is done. Now if I can get the above info. it will be up and running!
The machine had an anailam Crusader CNC. If anyone needs any of it's cards other than the Display card. The machine ran fine, but the display
gave me fits and finally did not work.
Thank you in advance,
Gary
