586,698 active members*
3,083 visitors online*
    Jan 2004
    490
    Centering blocks
    Had the idea last night...instead of making some centering blocks out of MDF or whatever, just get the next size up pipe flange and drill and tap four holes toward the center! Steel threads hold a lot better, and its not like the things are really that expensive!
    Aug 2003
    53
    Nice Idea!!
    Would have liked to have had that brain_art a month back when I was working up 16 pcs (ply versions) with a blunt holesaw. I think the smoke is just starting to clear in my shop
    Nov 2003
    314
    Does sound like a very good idea, what thickness would the wall of the flange be that you'd be tapping ?
    Jan 2004
    490
    I think that the flanges are 3/16". With a fine thread bolt there should be plenty of threads in the piece. It could even be backed up with a nut on either side if the ID of the flange is big enough. jam nuts on the outside would be a good idea in either case.
    Stop talking about it and do it already!!!!!
    Nov 2003
    121
    You could add a short nipple or a half of one and tread that . Schedule 80 will also give you more thickness. Good idea.
  1. iko blocks seem too stiff.
    By bgolash in forum DIY CNC Router Table Machines
    Last Post: 03-14-2005, 08:50 PM
  2. end blocks for ball screws
    By senor J. in forum DIY CNC Router Table Machines
    Last Post: 02-26-2005, 09:05 AM
  3. RFQ Simple Aluminum Bearing Blocks
    By b0gh0s in forum Employment Opportunity
    Last Post: 12-23-2004, 10:57 PM
  4. screwless vice clamp blocks
    By JFettig in forum Benchtop Machines
    Last Post: 04-16-2004, 01:03 PM
  5. Making your own pillow blocks and Rail mounts?
    By Zephrant in forum DIY CNC Router Table Machines
    Last Post: 05-20-2003, 12:34 AM
