586,075 active members*
4,127 visitors online*
IndustryArena Forum > CAD Software > Autodesk > Adobe Illustrator Files
    Apr 2003
    89
    Does anyone know of a shareware/freeware program to convert Adobe Illustrator 8 files to dwg or dxf?
    Apr 2003
    470
    Adobe Illustrator 8 will export as a DXF already. Most illustation packages will import .ai files and can save/export as DXF as well.
    Rhino can read .ai files as well.
    There is a pretty cool piece of software by IMSI called Hijack Pro that converts most common vector and other graphics types. There is a free trial as well.
    http://www.imsisoft.com/prodinfo.asp?t=1&mcid=99
    Nathan
    Apr 2003
    89
    Thanks Nathan
    I ended up using Rino's 25 day trial.
    I needed the .dxf for use with a laser cutting machine and the job is on a tight schedule so you really saved my bacon.
    Thanks again for your help.:cheers:
  1. Adobe streamline raster to vector.
    By nervis1 in forum Uncategorised CAM Discussion
    Last Post: 11-23-2004, 04:09 AM
