Re: Z feed rate changing! Please help!
I think there is something else going on here.
G64 (the opposite of G61) is the default mode for linuxcnc (and PP).
Indeed, Tormach specifies in their manuals to have this in your "safety block" at the beginning of your cnc programs;
Originally Posted by
TORMACH
N2 G90 G80 G40 G54 G20 G17 G50 G94 G64 (SAFETY BLOCK)
G64 specifies that the cut can depart from the programmed path by the specified P & Q values, whereas G61 demands "exact cut", which could make your cut path somewhat jerky. The trajectory planner was an area of the core linuxcnc that Tormach funded development of. Note the Linuxcnc manual warning quoted below.
What version of PP are your running?
LinuxCNC manual
G61 (exact stop mode): G61 tells the planner to come to an exact stop at every segment's end. This ensures exact path following but
the full stops can be harmful to the workpiece or the tooling, depending on the particular cut.
G64 (continuous mode): G64 tells the planner to sacrifice path following accuracy in order to keep the feed rate up. This is necessary for some types of material or tooling where exact stops are harmful, and can work great as long as the programmer is careful to keep in mind that the tool's path will be somewhat more curvy than the program specifies.
LinuxCNC Documentation Wiki: TrajectoryControl
None of which explains why you are plunging at greater than the specified speed. Sounds like a bug.
Tim
Tormach 1100-3, Grizzly G0709 lathe, Clausing 8520 mill, SolidWorks, HSMWorks.
