586,103 active members*
3,339 visitors online*
IndustryArena Forum > MetalWorking Machines > Drilling- and Milling Machines > Help needed to incorporate harmonic drives in a 4th and 5th axis head.
Results 1 to 2 of 2
    Feb 2006
    43
    I recently acquired two harmonic drives and wish to use them to build a 4th and 5th axis head. It will be similar to a doughty drive. The harmonic drives are only the large ring, the flexible cup and the wave generator. There is no housing so I will have to I corporate these in the head itself.
    I will be mating these to an 80mm water cooled spindle.
    Jul 2015
    57
    Re: Help needed to incorporate harmonic drives in a 4th and 5th axis head.
    Hi, I'm currently building a very similar machine. Check out my thread of you want:
    http://www.cnczone.com/forums/cnc-wo...ml#post1906402
  1. harmonic drives really have 'zero' backlash? really better than planetary reduction?
    By bebob1 in forum Mechanical Calculations/Engineering Design
    Last Post: 12-28-2014, 11:17 PM
  2. Harmonic Drive 4th axis - PEU
    By PEU in forum DIY CNC Router Table Machines
    Last Post: 04-27-2014, 04:33 AM
  3. Anyone tried these stepper & harmonic 4th axis from China?
    By Aquaaddict in forum Benchtop Machines
    Last Post: 03-22-2013, 05:25 PM
  4. Harmonic drive 4th axis for the X2
    By scubaben in forum Benchtop Machines
    Last Post: 03-04-2012, 07:51 PM
  5. 4th axis- planetary vs harmonic?
    By walter in forum DIY CNC Router Table Machines
    Last Post: 10-03-2005, 04:46 AM
