587,043 active members*
3,013 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Need advise on Fanuc 21M or 0-M control operation
Results 1 to 6 of 6
    Dec 2006
    26
    I am new to the Fanuc 21M and 0-M controllers, I have been programming Fanuc lathe controls since 1994, but never owned a mill contol. I need help setting the G54 - G59 fixture offset locations. Is there a button that can be pushed on the control that will automatically set the x & y values for you or do you have to manually enter the position into the control? I need to know what value to enter, is it the Relative value or the Absolute value if it has to be entered manually? Please reply to this post , thanks in advance,
    Nov 2006
    175
    All the values are related to MACHINE coordinate system (G53)
    Try <offset/setting><work><X><0>now new button appears [MEASURE]
    Instead of X0 you can enter for example Z100. [MEASURE]
    Oct 2006
    586
    yeah what f-bu said find you X0 Y0 go to offset page then to work offset highlight X enter X0 then hit Mearure same with i use the (EXT)
    Dec 2006
    26
    thanks for the advise
    I will check it out, thanks, Barney
    Dec 2006
    51
    The Measurment Function is an Option and not all Machine tool builders purchase this from Fanuc.
    If you Don't Have the Measurment Function as a softkey on the Work Screen, then you need to manually key in the work offset.
    Make sure you use the MACHINE positon from the Position Display.
    If your Machine Position is always Metric, let me know...
    There is a Parameter to make this match the Inch / Metric setting.
    Dec 2006
    26
    thanx
