Hi guys,
I'm using Mastercam V9 and I'm wanting to run a mill that I've just bought off it. The mill is a Hurco BMC 20, I'm working in metric and I can send programs to the machine ok. What's happening is mastercam creates the programs with a decimal point in the feedrates, e.g. "F1500.0". The machine will not accept this and says the decimal point is "illegal". I can edit the program to remove the decimal points from all the feedrates before I send it to the machine, which isn't so bad for a small program but something big that needs drip feeding will be a bit of a hassle.
Is there any way I can set up Mastercam to not produce the decimal point in the feedrates by default.
Thanks in advance,
Steve.
