586,096 active members*
3,431 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Chinese Machines > Am I the only guy milling steel on my Chinese 6040??
Results 1 to 6 of 6
    Jan 2016
    33
    I can't even find youtube videos on it. Anyone else milling steel with their 6040 routers? I ripping up hot rolled steel right now with my 12.7mm end mill at 2,500mm/min feed, 1mm doc, 11mm step over. Its doing great so far, my end mill inserts last a long time & non indexable end mills can mill for days.
    Re: Am I the only guy milling steel on my Chinese 6040??
    Where's your videos?
    Aug 2004
    780
    Please share a video ..
    Mar 2014
    1131
    I tried this once.
    Cutting C45 steel in the video.
    May 2014
    97
    I have been milling 6061 with a substantially stiffer machine than a 6040, a 2.2kw spind with a smaller D end mill, slightly less aggressive feeds, and smaller step over. I too would like to see a vid.
    The guy in this vid has a machine that is probably comparable to mine (as much as you can tell from a pic) and he is doing 700mm/m, 4mm endmill, full WOC, .5mm DOC. And the coated end mill is sparking; so I wonder about the life. Perhaps if he had at least some air cooling the cutter and aiding in chip evac. IDK. I have this vid bookmarked in case I need a part in steel.
    Also looked at ONSRUD 83-300 series router bits that are made for high speed milling of steel.
    May 2014
    97
    Well I checked YouTube to see if anyone was doing what OP was claiming and I came across his YouTube.
    Vid
    You should upload a new vid where I assume you have a little more experience with the tooling.
  1. My Chinese 6040 Experience So Far
    By kronick in forum Chinese Machines
    Last Post: 05-12-2018, 11:48 AM
  2. Chinese 6040 CNC Router
    By ecope in forum Chinese Machines
    Last Post: 11-02-2015, 10:07 PM
  3. Upgrading a 3020 chinese milling machine to 6040
    By redou in forum Chinese Machines
    Last Post: 09-08-2015, 04:31 PM
  4. 6040 CNC Router (Chinese)
    Last Post: 10-14-2014, 08:57 PM
