586,540 active members*
3,001 visitors online*
Results 1 to 6 of 6
    Sep 2006
    126
    meldas 50 Series
    Dear Farum,
    I am looking for parameters of Milling CNC Feeler FV-800SE (made in Taiwan) with Meldas 50 Series controller.
    If you have these parameter or similar type, please help me.
    Nastek
    Feb 2005
    91
    nastex,
    Bear here,
    Texas ,U.S.A.
    I run a Mitibushi Meldas 50 4Xs set up on a
    lathe .What are you looking for,pataculars ?
    If I can help,Leave messages here,Also,
    Call out for Al ,I think he dose the mitibushi.
    24223
    The problem is the parameter values are machine specific, you either need from the OEM or someone with the identical machine.
    Al.
    Albert E.
    Sep 2006
    126
    I have looking these parameter in indonesia agent, but they can't help me.
    because i bought the machine in used condition by general trading company.
    I have ask to the Feeler company in taiwan, but they don't respond too.
    do you have a suggest for the problem?
    thanks
    Nastek
    24223
    The only solution in a case like that is to get the parameter manual, and reconfigure the parameters one-by-one, as would be done when the machine is originally set up.
    Have you lost the parameters completely?
    Al.
    Albert E.
    Sep 2006
    126
    Al.
    Dear Al,
    Happy New Year, for you and the Forum
    all parameters are lost, because the power supply burn out, and the battery spoiled,
    the machine have stop above 2 years, and i would to operate the machine again.
    i have repaired the power supply, and menu appears normally.
    what yours suggest?
    awaiting your replay.
    thanks
    greeting
    Nastek
