Originally Posted by
Ahamay17
All I cut is aluminum and as I mentioned the issue has shown with the machine near spotless...I have modified the coolant spray and toolpaths to keep the chips washed off of the machine, almost all of the chips end up on the stand so I don't think it is chips but I would never completely them rule out...
The ruined parts came from us running the program not realizing the Z axis was .050" lower then it was originally zeroed at...The tools ruined were the result of very aggressive cuts and an additional .050" cut depth...the actual drop itself did not damage anything...
I don't count on the proximity switches to repeat accurately, because I know they don't...Currently I only reference home when we have had a crash and coordinates might be off, which would render my soft limits useless. Because I have to have the sensors unplugged to get through longer runs, I need my soft limits to be accurate...Until recently for long production runs we have turned the machine off then back on and continued cutting where we left off without re-zeroing, without any issues, guess I have just been lucky for the last 8 months... What probe and screen set are you using? All my fixtures have a bulit in zero block for using an edge finder which is tedious compared to using a probe, so I am looking to switch to a probe...
Ray
