586,546 active members*
3,295 visitors online*
Results 1 to 16 of 16
    Feb 2006
    66
    Advice on Hardinge CHNC retrofit
    My CHNC is on it's last leg with its AB 7370 controller and I am looking to retrofit it. Almost everything I am reading here indicates that any of the commercially available retro kits are crappy so I am looking to build my own PC-based controller. I am thinking about using Gecko drives with Mach software. My concern is that the motion of the axis will not be fluid enough due to the step pulse output of the software. Is this a valid concern and if so, what other options do I have?
    Also, does anyone know if the Mach software can handle the automatic turret on the lathe?
    Any advice/info is appreciated. Thanks.
    -Ryan
    Aug 2005
    828
    Take a look here there are a few people that are working on CHNC's:
    http://www.machsupport.com/forum/ind...267&board=27.0
    Dennis
    Apr 2004
    79
    If you can go with digital servo the motion should be smooth.
    It will show up most when changing direction of the tool path.
    My hnc ran with AH-HA soft/hardware and did all of the original functions.
    I changed to stepper motors but servos would be better.
    I'm changing to M3 touchscreen with grex right now.To index the turret you first fire the relay to index turret then read 4 inputs combine them to a binary number from 1(0001) to 8(1000). When they match the desired tool fire the turret stop/lock relay then release the index relay. Next check that the turret is down(wait for sensor output) and release the stop/lock relay.Ypu may need to adjust the turret encoder for timing.
    Nov 2004
    164
    I redid a 2-axis toolroom lathe with a bad Anilam controller. I had success using Rutex 991H, step and direction to +/- 10 Volt, controllers feeding my existing servo drives. It was much cheaper then purchasing new drives since my Westamps were still performing well. Rutex is still in business and are going through some chip changes right now but they might still have some of the 991H or equivalents in stock. Maybe someone else makes a competing product, anyone?
    Mach3Turn had enough user configurability for me to get the multipass threading to work. And my spindle control is about there through mod-bus communications. I don't trust my pneumatic turret enough not to put in a M00 to verify tool change.
    Mach is the best open loop (closed within the drive only) PC control option I've run into. Probably one tenth of the hardware cost of the next closest closed loop pc lathe option that I am aware of (www.mdsi2.com). I don't think EMC could be considered right for lathe at this time.
    Mar 2004
    1543
    I've just recently finished refitting a CHNC with Camsoft. The machine is better than new. But Camsoft is an expensive control - may be more than you'd like to spend.
    Just my opinion, but using a keyboard to contol a commercial CNC machine sux. I installed all the control buttons and dials you'd see on any recent name brand control. This resulted in 50 inputs and 20 outputs. Way more than you can do with Mach.
    Karl
    Karl
    Aug 2005
    828
    jmullett,
    Here is a similar product and there is af few people runing them on the forum:
    http://www.skyko.com/products/
    If you need a lot of I/O's you can get a PLC to talk to Mach over ModIO:
    http://www.machsupport.com/forum/index.php?board=35.0
    Dennis
    Apr 2004
    79
    Hey Karl how about a picture of that control.
    Mar 2004
    1543
    Quote Originally Posted by Drew View Post
    Sorry, I'm about 2000 miles from it right now. I'll try to remember when I get home.
    Karl
    Nov 2004
    118
    Karl,
    We can do 100+ I/O on any number of things... We are working on Galil (that can have 64 points) and you could add a PLC (over modbus). This could get you more IO then you could ever need I am with you and I HATE the KB! Every machine that I do has a Nema 4 touch screen, knobs and buttons! I use a PLC because it is only 200.00 for one and I don't need to get all the opto 22 stuff. I love the opto 22's but they add up fast!
    Just wanted to tell you that it is not all about the printer port any more We are just about to start Delta Tau as well.. Man they have nice stuff!
    Brian
    Mar 2004
    1543
    Brian, I continue to be amazed at how fast the MachX software continues to be advanced...
    I remember all to well problems coordinating Modicon PLCs over Modbus with GM-Fanuc robots...( I was an engineer on a 50 machine molding and packing line)
    For example, with all the I/O in the host its a trivial thing to have a Jog swtich move an axis unless a limit switch is hit. With Mach, the axis move and the limit switch will be in the Mach software and the Jog input will be in the PLC. Do this for four directions, add a switch for jog speed, and then a handwheel for fine jog control and you can have a real mess.
    Here's hoping you come up with an elegant and simple solution to this problem.
    Karl
    Nov 2004
    118
    Modbus is not the best but it is good for IO that is not super high speed... We are looking into Ethernet Powerlink, I think you will be happy with the timing of that
    Apr 2004
    79
    Will Mach3 send commands through RS-232 to RS 485 converter board then to a OPTO 22 B100 brain on a 16 point rack? And can it recive a reply back from B100? And is there a limit to the number of input or output modules that can be on the rack other than a total of 16? (like 12in 4out or 5in 11out) Thanks Drew
    Nov 2004
    118
    Can't tell you as I have never used there IO Stuff like that
    So I am going to say No but that is because I don't know...
    Aug 2012
    Hardinge chnc
    I hope some one can help me out here! I just bought a Hardinge CHNC I think a 1982 or 1984. It has a retrofit control on it, and the guy that sold it to me said he ran it on camsoft. So I am thinking it's a camsoft control, but I am not sure. Nor do I know what to look for, I am new to CNC's, and retrofits so I have a lot to learn.
    He said the encoders have been changed to digital, and that the only thing thats hooked up is the air collet closer, the Y and Z, and the spindle motor. The turret and the coolent are not.
    I bought the lathe as is, there was no PC or software, so I could not even see it run, I had to take his word for it. But you can see alot of new parts in the control box, and a wire that hooks to the PC.
    24223
    Camsoft requires a PC and usually a Galil PCI slot motion card is fitted for controller.
    If this is missing that would be the heart of the machine?
    Not sure what you mean by digital encoders, unless absolute? Galil do not use this type.
    Al.
    Albert E.
    Aug 2012
    hardinge
    Thank you for your reply, the lathe is about 50 mile from home untill I make room for it, but I will check it this week and I hope I will have more info on it.
