586,119 active members*
3,510 visitors online*
IndustryArena Forum > CAM Software > Uncategorised CAM Discussion > CAM Software for Wood Lathe with Swivel Cutter
    Jan 2016
    4
    Hi all,
    I was wondering ifsomeone could help me,
    Im toying with the ideaof completely changing how we program a Hapfo 7000 Lathe as I am currentlytrying to figure out how to use its dated CAD/CAM and was hoping we could use amore modern package,
    I’ve spent some timegoogling but im not entirely sure anything will have the functionality we need,
    Theidea is, create a DXF of the design required, load the DXF into a CAM packagewhich can create the g-code required.
    The issue is that the cutter has the ability to be in 3 differentpositions (Swivel Left, Swivel Centre and Swivel Right) of which I have theG-Code, but can this be input into a CAM package to make this more userfriendly? as the idea at the moment isto teach a number of people how to use this machine.
    The code is as follows
    M65 P1 (TOOL RIGHT)
    M64 P0
    M65 P0 (TOOL LEFT)
    M64 P1
    M65 P0 (TOOL CENTRE)
    M65 P1
    An example of thesecodes being used within a program:
    G90.1 (Absolutedistance mode for arc)
    G61 (Exact Path moderemoves tool compensation)
    M65 P2 (spindel on/Zoff)
    G00 X 426.817Y45
    G01 X 426.817Y55.642F3000
    G01 X 426.817Y45.642F1200
    G01 X 431.352Y25.926F600
    G01 X 442.787Y24.349
    G01 X 457.573Y20.406
    G01 X 480.246Y16.265
    M65 P1 (TOOL RIGHT)
    M64 P0
    G01 X 455.915Y5.803F600
    G03 X434.176Y22.5I434.176J0
    M65 P1
    G01 X -2.585Y22.5F600
    M65 P0 (TOOL LEFT)
    M64 P1
    G01 X -1.571Y17.7F600
    G01 X 0Y17.7
    G01 X 50Y17.7
    G01 X 50Y22.467
    G00 X 50Y45
    M65 P1
    G00 X 426.817Y45F600
    M65 P1
    M02
    If anyone could help itwould be very much appreciated,
    Jun 2006
    3063
    Re: CAM Software for Wood Lathe with Swivel Cutter
    I've no idea if SprutCAM will work for you, but they do have some sophisticated machine configurations, including ones for painting and knife cutting.
    https://www.youtube.com/watch?v=dr68mjZIGos
    Since you are in the UK, you should probably contact Dave at SprutUK for more info:
    Home - Sprut Technology (UK) Ltd. Homepage
    Mike
    Jan 2016
    4
    Thank you for the reply,
    in the meantime after some trial and error and looking through the code generated I narrowed down the issue and have now sorted everything,
    thank you
    Glass CNC Machining (8 Years) | http://www.glasstops.co.uk/ | The machines I get to play with: http://www.glasstops.co.uk/about-us/glass-factory.html
  1. Phoenix Magnum Wood Lathe-need software!
    By Captain Crunch in forum Wood Lathes / Mills
    Last Post: 01-18-2021, 06:25 PM
  2. My chinese laser cutter won't work at all, software doesn't see the cutter
    By Sasa1234 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-01-2019, 04:09 AM
  3. wood ruff cutter
    By redridertwo in forum MetalWork Discussion
    Last Post: 01-22-2013, 05:02 AM
  4. Phoenix Magnum Wood Lathe-need software!
    Last Post: 02-04-2012, 07:32 AM
  5. Best Place to buy wood cutter in the UK?
    By andycorleone in forum DIY CNC Router Table Machines
    Last Post: 12-01-2008, 02:59 PM
