586,096 active members*
3,880 visitors online*
Results 1 to 8 of 8
    Jan 2016
    Mazak QT-15 servo lag excess x axis
    Hi everybody!
    I'm new to this forum and a newbie in CNC machining.
    We just bought a used Quick turn 15 1988 with Mazatrol CAM T-2 controller and I can't make move the X axis. As soon as I touch the joystick to manually operate the X axis I'm getting this message: sevo lag excess x axis. Then after I can't do nothing until I clear this message by shutting OFF and back ON the controller.
    Here is what I did to evaluate what's wrong:
    I verified if the ball screw is not jammed in the ball nut by unscrewing the servo motor and turning it manually. Result: I can easily make moves the axis.
    What else could be verified to understand what's wrong and how should I do to achieve it.
    Thank you so much in advance for your valued experience and knowledge.
    P.S.: sorry for my english writting, I'm a french canadian...
    Oct 2003
    321
    Re: Mazak QT-15 servo lag excess x axis
    Hi from Slovenia,
    When you get the alarm look at the axis servo TRA 31 or TRA 41 what you can see at the vertikal red led.
    Best regards
    Stan
    Jan 2016
    Dear stan,
    Thanks for answering me.
    Here what written on the x axis servo drive : MR-S 80Z-33A.
    Also today I got a different alarm when I tried to move the x axis with the joystik : 13 x drive alarm!
    Here is what the drive digital display show after getting the alarm = 32
    Is this help you?
    Regards.
    David
    Oct 2003
    321
    One of your IGBT is demaged.
    You must repair the servo MR-S1...
    Call Bill
    Www.gorzelectronics.com
    Quote Originally Posted by daveray View Post
    Dear stan,
    Is this help you?
    Regards.
    David
    Jan 2016
    Attachment 305500Attachment 305502
    Dear Stan,
    Thanks for your answer.
    Do you mean these components (see attached picture) must be changed?
    David
    I had the same problem in a VQC M32, the problem was X axis encoder failure., , So i had to replace the defective encoder.
    Oct 2003
    321
    Yes!
    Dear Stan,
    David
    Jun 2016
    I've got the same problem.
    Machine work normaly but when stay (changing tools or sld.) damage axis go to 20%-50% and alarm. IGBT or encoder?
  1. 431 z axis servo excess error
    By bassackwards142 in forum Fanuc
    Last Post: 06-25-2013, 02:46 AM
  2. Mazak QuickSlant 20 with Mazatrol T4 -ERROR 1: SERVO LAG EXCESS X1 AXIS
    By Acustical in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-24-2012, 03:44 PM
  3. SERVO LAG EXCESS Y AXIS (Y axis won't home)
    By eltorio in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-19-2011, 01:10 PM
  4. Replies: 6
    Last Post: 01-14-2011, 05:16 AM
