586,072 active members*
4,439 visitors online*
Results 1 to 7 of 7
    Jan 2016
    10
    Wmd30vl cnc kit.
    Hello guys,
    I have bought a wmd30vl (long table) and want to convert it to cnc. I want to buy a kit from ebay longsmotor99 but am not sure what kit is ideal for my machine.
    I have asked longsmotor99 for assistance and they suggested this kit
    【German SHIP Promote】4Axis Nema23 Stepper Motor 435oz in 4 2A Driver CNC Mill | eBay
    What is you opinion, is it enough to run the mill?
    May 2005
    1397
    Re: Wmd30vl cnc kit.
    Looks ok, but it can be hard to tell...
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Jan 2016
    10
    Why hard? Do you have the same mill? I just want to know if someone else did this mod.
    May 2005
    1397
    Quote Originally Posted by CAM1911 View Post
    Why hard?
    Because humans lie.
    I do not. Was just trying to help with a quick review. I don't see any obvious problems.
    Jan 2016
    10
    Ok, so what do you suggest to buy as a kit, can you guide me or maybe give me few links on ebay. Thanks
    Sent from my PSP5504DUO using Tapatalk
    May 2005
    1397
    Again, I don't see anything wrong with that kit.
    I'm not a kit person myself... I like to build things from found junk or salvage or scrap or used stuff from eBay.
    This is my kind of machine. Looks like hell, but works, costs nearly zip, and you LEARN
    Built from Scrap: This CNC Machine Was Made for $160 | Make:
    2nd generation:
    https://youtu.be/mJ-TZvFpY58
    Another, nicer looking:
    $20 CNC Machine
    Toms: Hardware store drawer slides, skate bearings on pipe/rod/angle, threaded rod, stepper motors, laminate router. The big advantage here is that it can all be cut, filed, and bolted together with little more than hand tools.
    http://www.cnczone.com/forums/102542-post270.html
    Engraving with the Easy CNC mill - YouTube
    http://www.instructables.com/id/Easy...lling-Machine/
    Toms Easy CNC is documented in 4 videos and and instructables page. Uses pipes and fittings from the hardware store.
    If you want something nicer looking, and more powerful, this is an interesting design:
    http://www.vicious1.com/specifications/
    Jan 2016
    10
    That is quite interesting. The basics are always the same for all machines. The idea is the key. Thanks for your input.
