586,080 active members*
3,543 visitors online*
    Jan 2012
    58
    4th axis weird behavior
    Finally got my 6" 4th axis drive installed on my 2 month old PCNC 1100. Everything is functioning - jogging A axis works both directions, and the drive responds to G00 & G01 commands, however....
    The drive rotates 25% farther than the G0/G1 command told it to.
    For example: a G0 A0 command always moves the drive to the "0" point, but a G0 A20 command causes it to rotate to 25 degrees; a G0 A360 command causes it go a full revolution, past zero and stop on 90...?
    Must be some kind of setup problem, but I can't find anything that references this problem.
    Anyone have any ideas on this?
    Gerry Kmack
    Sent from my iPad using Tapatalk
    Dec 2008
    740
    Re: 4th axis weird behavior
    Quote Originally Posted by Gerry Kmack View Post
    Gerry Kmack
    The first thing I would check are the DIP switch settings on the stepper drive.
    Step
    Apr 2004
    5737
    It sounds like your steps per unit settings are off. In motor tuning, reduce that number by 20% for the A axis and re-test.
    Andrew Werby
    Website
    Jan 2012
    58
    It was the DIP switch settings - reset them per the spec for a 6" rotary and now it works perfectly!
    Thanks!
    Gerry Kmack
  1. Hitachi m12vc weird behavior when attempting to touch off
    By rlrhett in forum DIY CNC Router Table Machines
    Last Post: 12-20-2014, 10:58 PM
  2. Weird behavior and crashes...
    By subnoize in forum MadCAM
    Last Post: 07-14-2014, 10:42 AM
  3. Replies: 17
    Last Post: 04-07-2013, 04:34 PM
  4. Weird Cutting Behavior. OMC Controls
    By EricMFG in forum Fanuc
    Last Post: 08-21-2012, 01:59 AM
