I have this up on the Autodesk/CAM forum, but was asked to put it here also. So here it is. This is NOT from Tormach, this is my doing, but I've been using it all along and it's working quite well. It support a bunch of things:
X+ ( turret ), X- ( QCTP ), and gang tooling - and any combination thereof.
Looping, through the use of 'PassThroughs'.
Importing outside gcode, through use of 'Actions'.
Bar Pullers, through using the above, and 'Stock Transfer' ops on Fusion.
Lathing on the Tormach Mills.
Highly advisable to read the instructions - they are brief. You will need to change the extension from '.txt' to '.cps'. This forum wouldn't let up upload a '.cps' file for some reason.
That said, here is the disclaimer:
[usual] Disclaimer: It's a homegrown effort that seems to be working OK on *my* machine, but *may* have mistakes and is not guaranteed in any way. Using this software may cause scrapped parts, tool breakage, machine damage, and otherwise ruin your day! Contains unverified code to support 'Turret mode', I (sniff) don't have a turret yet! Please check the PathPilot tool path window, check gcode, and run air passes, to check validity before cutting parts.
Happy posting!
