Hello All:
I am a fairly experienced "hobby" CNC router user running a 2' x 4' machine with Nema 23 570 oz/in motors and a Porter Cable 3.75 HP router. I upgraded the motors and router from much smaller components and yes, I do realize that I went "overboard" when I did it. I thought I needed the extra torque and power but in hindsight I was wrong...which is why I am writing this now.
I use Vectric Aspire and Mach 3 for all of my work and love this combination of software. I have been cutting mostly wooden and acrylic signs and boxes and some aluminum at times and have been able to produce some fairly nice products with the setup I have. Recently I have been cutting a lot of 1/8" Baltic Birch plywood from the local "Woodworkers Source" and have fallen in love with this product. It cuts quickly and beautifully and it is also fairly inexpensive. So...here it is.
My younger sister has recently been hanging around with me in my shop, along with her daughter, and they have seen me produce some pretty cool stuff using the 1/8" Baltic Birch plywood and now they would like to try their hand at running a CNC router. I have been teaching them in my home shop and I think they are ready to get their own machine. Of course, I have volunteered to build one for them.
I would like to build them a "moving table" router around X = 16" Y = 24" Z = 5" with the table moving in the 16" direction but I only want to build it sturdy enough to cut 1/8" to maybe 1/4" Baltic Birch plywood and maybe some acrylic also. I definitely do not want to go "overboard" again. I am thinking of building it from HDPE or maybe PVC combined with 8020 extrusions. I would like to use Acme screws or maybe ballscrews for this project. I do not want to build a belt driven machine.
I want to use a Makita 1.25 HP "trim" router as the spindle and I need your help in deciding which stepper motors I should use as well as recommendations for ballscrew size and maybe info on motor drivers and/or controllers. I chose the Makita 1.25 hp router because it is capable of spinning at 30,000 rpm and I think the higher speed will be good for cutting the thin plywood. I have been cutting this plywood on my larger router using a .05" bit spinning at 21,000 rpm with a cutting speed of around 70 inches per minute and cutting the full depth of the material at 1/8" with very good results (no broken bits) and I want to be able to do at least the same on this new machine. Maybe even get a little faster cutting speed out of it since the "spindle" will be spinning an additional 10,000 rpm faster than my larger machine?
Any and all recommendations will be greatly appreciated and I will be posting drawings and photos here as I go along for anyone interested.
Thanks, in advance for all of your input.
