586,047 active members*
3,683 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > How to identify a stepper motor and AC servo motor? (by its appearance)
Results 1 to 7 of 7
    Jan 2016
    Hi guys,
    I'm working on the motors during this semester, and I have an assignment like this:
    How to identify whether a motor is a stepper or AC servo motor w/o open the inner parts (recognize it through its shaft, cover, fan, base... only), because they look almost the same for newbies?
    From what I have found out so far, the only difference is the diameter of the shaft, and stepper motor doesn't have an encoder while AC servo always has one. .
    Thanks.
    15362
    Re: How to identify a stepper motor and AC servo motor? (by its appearance)
    Quote Originally Posted by thanhvu94 View Post
    Hi guys,
    Thanks.
    An AC servo will only have 3 phase wires, and a Ground, as stepper motor will have wires 4 6 & 8 wires there are other stepper wiring arrangements as well this is the most used, Steppers can also have encoders as well, so don't get caught with that
    Steppers can also have the same diameter shaft, it will depend on the power of the motor as to the shaft size/diameter
    Attached Thumbnails Attached Thumbnails Stepper 4 wire.PNG   Stepper 6 & 8 wire.PNG
    Mactec54
    Jan 2016
    Thank you so much. Is there anything else besides wiring? (the cover, the base). Or there is no other differences?
    And I also have such a huge question. Stepper can run very hot when operating, why there is no cooling fan/heatsink for it?
    Thank you.
    May 2005
    1397
    Very good question. I often wonder why people don't put CPU coolers on hot running stepper motors. It helps enormously. Stepper motors can lose a significant percentage of their max torque when hot.
    James hosts the single best wiki page about steppers for CNC hobbyists on the net:
    http://www.piclist.com/techref/io/steppers.htm Disagree? Tell him what's missing! ,o)
    Because the heat doesn't hurt them, so why bother?
    May 2005
    1397
    If heat doesn't hurt them, then why do all stepper motors have a maximum temperature rating? Why did NEMA bother to come up with Class ratings for max temp? Why did Curie find the temperature at which magnets lose their magnetism?
    Stepper motors /generally/ aren't hurt by heat under normal operating conditions. But they can be. And they DO lose torque as they heat even in normal operation. Perhaps as little as 5%, but sometimes more depending on the quality of the magnets used in the motor.
    More detail and references:
    techref.massmind.org/techref/io/stepper/heat.htm
    Oct 2005
    1145
    Ac servos can have a lot more wires
    3 phase wires
    4-6 hall sensors wires
    3-5 encoders wires
    2 brake wires
    2 posible temp sensor wires
    DC servo
    2 phase wires
    3-5 encoder wires
    Most of the time with servos teh phase wires are in a seperate group so there are 2 connectors or wire groups coming out of the body
  1. Can anyone identify this servo motor?
    By Tig in forum Servo Motors / Drives
    Last Post: 08-04-2011, 12:49 PM
  2. 9 wires stepper motor help identify.
    By franzschluter in forum Stepper Motors / Drives
    Last Post: 04-23-2010, 02:08 PM
  3. Help me to Identify these stepper motor!
    By eranglr in forum Stepper Motors / Drives
    Last Post: 11-07-2009, 01:59 PM
  4. how to identify my stepper motor
    By Syphonics in forum Stepper Motors / Drives
    Last Post: 12-20-2006, 12:29 AM
  5. How to identify a Servo motor
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 10-23-2003, 05:42 AM
