586,201 active members*
4,178 visitors online*
    Sep 2014
    22
    SL-25 X-axis ball screw removal?
    have a bad ball nut and ball screw on our mori seiki SL25,
    and i got all the covers off and i can see where the motor and the upper thrust bearings and where the Ball nut would un-bolt from the cross slide.
    but i can figure out how to get to the thrust bearing block at the bottom with the 3 angular contact bearings and the nut at the end of the ball screw.
    there is a large block that is inbetween the ways that looks like it could be removed to access it. but cant seem to figure out how to remove it.
    here are some pictures
    Apr 2021
    8
    Re: SL-25 X-axis ball screw removal?
    Quote Originally Posted by NoGoodNolan View Post
    Did you figure out how to remove the ball screw, I just finished on e and just noticed your post,
  1. Mazak VQC-20/40B - X axis ball screw removal
    By nlh in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-11-2014, 01:04 PM
  2. Replies: 2
    Last Post: 02-27-2013, 12:56 AM
  3. Takumi V8 Ball Screw Removal
    By rasauber in forum Uncategorised MetalWorking Machines
    Last Post: 10-17-2012, 02:50 PM
  4. Z axis to ball screw or not to ball screw
    By brian257 in forum Bridgeport / Hardinge Mills
    Last Post: 03-28-2012, 09:39 PM
  5. Ball Screw Removal
    By smarbaga in forum Linear and Rotary Motion
    Last Post: 11-24-2005, 08:56 PM
