586,108 active members*
3,097 visitors online*
    Mar 2012
    27
    Question huangyang vfd and spindle question
    Is it possible and/or safe to program the VFD without the spindle connected?
    thanks for any informed answers.
    k
    Jan 2015
    Re: huangyang vfd and spindle question
    Yes, it is perfectly safe, the VFD does not communicate with the spindle at all unless it is turned on. Do not - however - attempt to run the VFD without the spindle connected (i.e., dont press the green button unless the spindle is properly connected).
    24221
    I have never experienced a problem yet testing a VFD without a motor connected.
    Al.
    Albert E.
  1. Actual settings for Huangyang 2.2 kw VFD
    By ajfoxy in forum Australia, New Zealand Club House
    Last Post: 07-31-2014, 04:35 AM
  2. Newb Question: Difference Between 40 Taper spindle and a 50 taper spindle
    By AndrewJP in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2010, 12:00 AM
  3. spindle question
    By hall6ppc in forum Bridgeport / Hardinge Mills
    Last Post: 01-15-2010, 01:54 AM
  4. Question about spindle on SX3
    By Kevin Harpham in forum Syil Products
    Last Post: 01-02-2007, 09:51 PM
  5. R8 Spindle Question:
    By CROSSHATCH in forum CNC Tooling
    Last Post: 09-08-2006, 08:01 PM
