586,121 active members*
3,535 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Will Spindle Servo Drive lose parameters when disconnected from power?
    Jun 2010
    45
    Got a bad spindle servo drive. With an error, I can't seem to be able to access and record the parameters. Does the battery backup also protect the parameters of the servo drive. The control is 0M-B. Servo drive is an S3. I have the maintenance manual, but it doesn't say anything about parameter retention.
    Thank you,
    Roger
    May 2015
    70
    Re: Will Spindle Servo Drive lose parameters when disconnected from power?
    Parameters are written to EPROM, no battery backup required. Removing drive from machine or power source will not affect parameter retention.
    Jun 2010
    45
    Quote Originally Posted by Mike283 View Post
    Thanks Mike.
  1. Haas VF-0 Spindle Drive Parameters, Please
    By roofis27 in forum Haas Mills
    Last Post: 05-26-2022, 04:40 PM
  2. MISSING AC SPINDLE DRIVE + 3 AXIS SERVO DRIVE
    By Affaq999 in forum Vertical Mill, Lathe Project Log
    Last Post: 02-20-2015, 03:50 AM
  3. 97 VF-3 spindle drive parameters
    By GITRDUN in forum Haas Mills
    Last Post: 09-03-2012, 12:13 AM
  4. 1993 VF2 Spindle Drive Parameters
    By tbussan in forum Haas Mills
    Last Post: 10-06-2010, 03:59 PM
  5. What happens when you lose power
    By monte55 in forum Mach Mill
    Last Post: 05-04-2010, 08:13 PM
