586,980 active members*
3,280 visitors online*
IndustryArena Forum > CAM Software > Surfcam > Working with solids
    May 2008
    20
    Working with solids
    Does anyone use Surfcam V5.2 (or other version) with solids to do 2 axis milling?
    I've been using Spaceclaim to make solids and I'd like to export to something, then import to surfcam, but all I'm getting is wire frames and selecting pockets or contours is difficult.
    I'm thinking that having the depths to choose from might be quicker with the solid.
    Any input welcome.
    Nick
    Apr 2003
    637
    Re: Working with solids
    What file format are you using to import? Every version I've used, including 5.2, up to V6 does not use solids, only wire frame and surfaces. If you use XT parasolids, for example, to import you will get your surfaces by default on level 223 and wire frame on level 224. You should be able to chain select the wire frame to define the bottom or top of the pocket. Been doing it that way for 20 years now, no big deal.
    Feb 2006
    49
    Traditional Surfcam which is what you have really holds you back at the version you have, the current stuff works well in shaded / wire frame mode but you still pick profiles. the biggest deal when using it(current ver) that way is to set the geometry to top of bottom accordingly. by the way hi moldcore its been a long while.
  1. Replies: 0
    Last Post: 04-20-2015, 10:07 PM
  2. Working with Solids
    By aldepoalo in forum BobCad-Cam
    Last Post: 01-17-2013, 07:58 AM
  3. Working with Solids
    By timmydabull in forum Mastercam
    Last Post: 10-02-2008, 03:55 PM
  4. working with solids
    By dewme5 in forum EdgeCam
    Last Post: 12-29-2007, 09:55 PM
  5. Need help working with solids in v21
    By mikesos1 in forum BobCad-Cam
    Last Post: 09-20-2006, 11:13 PM
