586,581 active members*
2,654 visitors online*
IndustryArena Forum > Community Club House > Machinist Hangout > Need a bit of help with this problem
    Jan 2007
    243
    Question Need a bit of help with this problem
    I have to calculate the number of pins in the diameter of a circle based on the circle radius (diameter) where the pins are tangent to each other and lying inside the circle diameter. Any help would be most appreciated. Thank you.
    www.WebMachinist.Net
    The Ultimate Online Source for Machinist Related Stuff!
    Oct 2013
    64
    Re: Need a bit of help with this problem
    .965" pins, using 13 pins as pictured in a 10" diameter hole.
    Jun 2014
    39
    If I've done my sums correctly -
    let R be the cavity radius
    let r be the pin radius
    draw a triangle abc between two adjacent pins, ab, and the center c
    bisect ab to make point d.
    adc is now a right triangle.
    let theta be the angle acd (the one at the center).
    let k be the length of the hypotenuse
    Now, since the pin must be centered on a and it's surface touch d,
    len(ad) = r
    Since the pin must touch the outside R,
    A) k = R - r
    and by trig definition of sin
    B) k = r sin(theta)
    substituting A into B
    r = (R - r) sin(theta)
    collecting r terms on left side
    r(1 + sin(theta)) = R sin(theta)
    divide by (1 + sin(theta))
    C) r = (R sin(theta)) / (1 + sin(theta))
    Now, let n be the numer of pins. Then 2n is the number of triangles similar to adc, so
    2 pi = 2n theta
    so
    D) pi / n = theta
    substituting D into C
    r = (R sin(pi/n)) / (1 + sin(pi/n))
    This solution is exact.
    The seemingly simpler solution is just to take a circle of radius (R-r) , take it's circumference, 2 pi (R - r), and divide by n,
    but this has an error, as it doesn't account for the difference in length along the arc and along ad for two triangles.
    As the number of pins rise the solutions converge, using two approximations
    sin(pi/n) ~= pi/n (the so-called 'small angle approximation')
    and
    1 + sin(pi/n) ~= 1
    Hope that helps
    Sep 2015
    Thank you I will try it out.
  1. Please Help. Having problem with CNC driver/card problem.
    By todatop in forum Commercial CNC Wood Routers
    Last Post: 02-09-2018, 05:40 PM
  2. Having problem with CNC driver/card problem
    Last Post: 04-09-2014, 05:45 PM
  3. Tube problem or powersupply problem? Help you to check out
    By Melody-gweike in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 10-05-2012, 04:09 AM
  4. daewoo puma 12lb tape format problem/parameter problem
    By robb12877 in forum Daewoo/Doosan
    Last Post: 08-25-2011, 06:13 AM
  5. Replies: 5
    Last Post: 08-04-2010, 11:33 PM
