586,102 active members*
2,415 visitors online*
IndustryArena Forum > MetalWorking > Moldmaking > dust collection for graphite?
Results 1 to 6 of 6
    Apr 2006
    25
    I don't want to spend tons of money for an expensive unit. What are my other option? I'm thinking about a wet/dry vac???
    Mar 2005
    14
    Be careful, Graphie dust is nothing you should breath too much of.
    I have been using a shopvac with a replaceable filter bag. The bags are used for fine dust vacuuming, like drywall sanding dust. They are available at Home Depot or Lowes for most makes of shop vacs right in the shop vac section. They are usually 3 to a package and only a few bucks. Just be careful when removing it from the vac itself. If you squeeze the bag it will send a black cloud into the air. I place duct tape over the opening then pull the bag from the vac. and of course, buy the smallest micron (lowest number) bag for best results.
    Nov 2006
    382
    break down and buy a torrit at an auction. I have been dealing with the wood dust collector for about 2 years and I want to thow it out. Get a torrit and save some money and lungs in the long run.
    Feb 2005
    224
    If you intend to cut graphite on a regular basis, spend the money to buy a used torrit dust collector. I made the mistake of thinking that I could use a shop vac, then I tried grinding some copper impregnated graphite. I suffered from swollen eyes and sneezing and itching for about a week, then went to the first auction I saw that had a dust collector and bought one. best purchase I ever made.
    Jim
    Jan 2006
    62
    Yea you really need a dust collector made for graphite if you plan on cutting alot. I wouldn't mess with the shop vacs. I have done it in a pinch and always regretted it. There's another option if you are only going to do this once or twice. You can use the coolant on your mill it will keep the dust down, but plan on replacing the coolant when your done and giving you system a good wash down.
    Mark Reynaert, President Mark Mold and Engineering [email protected] http://markmold.com
    Dust, a common household word that can be defined as a finely powdered substance of various matters often suspended in the air. This is no different with the dust generated when machining EDM electrodes. Anyone that has machined graphite knows that the particles generated from the machining process are very fine and have a tendency to remain airborne. However, unlike common household dust, graphite dust has characteristics that must be taken into consideration. This is the first of a two-part article that will discuss these characteristics and hopefully answer often asked questions when dealing with graphite dust.more details,you can read(2 parts):
    http://buygraphiteforsales.blogspot....hite-dust.html
    http://buygraphiteforsales.blogspot....te-dust-2.html
