Is there a trick to removing the pulley (ER16 spindle) from the spindle?
I have removed the setscrew but it is not moving, not sure how much force should be needed.
Andre
Andre
It is an interference fit. I recommend heating the pulley (propane or butane torch) while using a pulley extractor.
Yep shortly after I posted I found the info about it being a shrink fit.
A little heat and I did not even need the puller just a leather glove, it lifted right off.
Andre
