586,106 active members*
3,041 visitors online*
IndustryArena Forum > CAM Software > Vectric > Aspire > Mach probing wizard or Aspire Regular Grid Gadget
Results 1 to 9 of 9
    Feb 2016
    5
    After a probe in Mach3, I opened the .txt file in Aspire.
    The 2D and 3D views came up on the screens but they were inverted.
    I did a probe on a set of diagonal wire cutter jaws and what should have been a v groove was a raised prism.
    I'm new to the touch probing scene and don't know if I'm supposed to correct this in Mach or correct it in Aspire.
    I've used the search engines on both sites and can not find any posts on the topic.
    Any help would be greatly appriecated.
    moobster
    Re: Mach probing wizard or Aspire Regular Grid Gadget
    Are you importing with the gadget?
    Feb 2016
    5
    Yes, I'm importing with the "Regular Grid Gadget" in Aspire 4.5.
    I am using the digitizing wizard that comes in Mach3 for the probing routine.
    I'm messing with Z reversed in Machs homing limits and also with the hot keys for page up and down and trying to invert the point cloud from there.
    This is starting to look promising now. It appears that Mach somehow got set up on this new machine with Z+ making the axis go down.
    I'm going back out to try again.
    Oct 2005
    1145
    IF that were the case then the wizard generated code would never had worked as it assumes that Z- is down.
    Just a thought, (;-) TP
    Feb 2016
    5
    Quote Originally Posted by vmax549 View Post
    Yup, it didn't work.
    I'm out of ideas.
    Oct 2005
    1145
    IF you take teh points txt file and put a G01 F100 as teh first line then you can load it back into mach3 as Gcode and you see teh object you scanned. Does it look right ? It should.
    IF it does then the problem is in Aspire or its import routine.
    Feb 2016
    5
    Thanks for your help so far Vmax549
    I can't get it to read in Mach
    I tried to load it back into Mach with the G01 F100 first line and the status box reads "Bad character usedLine1"
    The g code has no x,y,z in the coordinates, so that may be the problem.
    Here is a sample of the first few lines of g code mach produced with the probe.
    G01 F100
    0.00000,0.00000,0.06000
    0.04997,0.00000,0.06000
    0.09995,0.00000,0.06000
    0.14992,0.00000,0.06000
    0.19990,0.00000,0.06000
    0.24987,0.00000,0.06000
    0.29985,0.00000,0.06000
    This hasn't hit the probed surface yet, it is still on it's way over but the probe tip is .060" below the top surface of the coin.
    I believe all I need to do is get a( - )in front of the z coordinate and all will be good.
    x's and y's seem to be good, it's just the z that's inverted.
    Jan 2007
    1795
    as I remember, accutrans has function to inserting the axis letters..
    shopbot producing this type output where no axis numbers outputted..
    Feb 2016
    5
    Attachment 307252
    Canadian Nickle
    I'm not sure what I did, but its working.
    This is what it looks like in Aspire.
    I think it was in the Z direction of Mach, cause the DRO would go more + the closer the probe got to the table,
    so the deeper the probe went the higher the number. This is the only way I can explain it.
    Thanks for your responses in helping me solve this issue. So, who won the game???
  1. Anybody using the regular commercial version of Mach 3?
    By JohnToner in forum Tormach Personal CNC Mill
    Last Post: 07-04-2015, 03:56 PM
  2. Fast Probing Routine/Wizard/Setup?
    By Bob La Londe in forum Digitizing and Laser Digitizing
    Last Post: 06-30-2013, 05:14 AM
  3. Mach 3 Probing Wizard etc.
    By geoff3881 in forum Mach Wizards, Macros, & Addons
    Last Post: 01-19-2011, 05:51 AM
  4. Probing with Mach III
    By GuitarEng in forum Mach Mill
    Last Post: 04-24-2008, 09:53 PM
  5. Mach and probing
    By KKutt in forum Mach Mill
    Last Post: 04-22-2007, 06:05 PM
