586,089 active members*
3,867 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > stepper driver using h-bridge to analog servo driver
    Dec 2010
    thank you yo those who give time to read this
    here is my problem:
    I have a set of yaskawa ac servo driver and motor -yaskawa sdg-as . it need an analog signal. a battery will make the motor run forward and with battery in reverse polarity will make the motor turn in reverse also.
    i'm thinking if a stepper bipolar driver output to___ an H-bridge to___ servo driver analog input. will this work, have anyone tried this before? or maybe a DAC or digital to analog converter?
    I am desperate to make this ac servo system running or it will be a dead investment. I am ready to listen to you please share your knowledge.
    checkout this out https://www.youtube.com/watch?v=xi2KYqW3Ulk.
    he made the driver running with the stepper motor connect with a coupling to a dc motor that produce dc voltage to make the ac servo system running.
    this is the H-bridge link: L9110S Dual DC motor Driver Controller Board H bridge Stepper for Arduino Free Shipping-in Integrated Circuits from Electronic Components & Supplies on Aliexpress.com | Alibaba Group
    Apr 2004
    733
    Re: stepper driver using h-bridge to analog servo driver
    You will need something like this to make it work
    Step2Linear, ViperServo
    Dec 2010
    thank you Sir
  1. Replies: 7
    Last Post: 01-10-2015, 05:49 PM
  2. Information on DQ860MA analog stepper driver
    By JVWilliams in forum Stepper Motors / Drives
    Last Post: 10-26-2014, 12:43 AM
  3. Best MOSFET Driver and MOSFET choice for an H-Bridge Stepper Driver?
    By joprinz in forum CNC Machine Related Electronics
    Last Post: 04-28-2011, 09:57 AM
  4. H-bridge Servo Driver design
    By EMMKAY in forum Servo Motors / Drives
    Last Post: 03-03-2009, 11:24 AM
  5. analog signal servo driver
    By zoeper in forum Open Source Controller Boards
    Last Post: 02-19-2009, 06:05 PM
