586,058 active members*
4,252 visitors online*
IndustryArena Forum > CAM Software > BobCad-Cam > Thread milling a 1/8-27 npt internal thread
Results 1 to 11 of 11
    Apr 2010
    38
    Can V27 with 3 axis pro create a thread mill program for a
    1/8-27 npt internal thread using a thread mill ?
    Thanks in advance for any help .
    Re: Thread milling a 1/8-27 npt internal thread
    Most thread mill manufacturers have an on-line application which will generate code to mill the thread you want, you can then integrate that into your own code,
    Regards,
    Nick
    Apr 2009
    3376
    or 3D engrave,,,you draw your leads and spiral
    Jul 2008
    70
    Why thread mill it ? I would just tap it in the mill
    Quote Originally Posted by WILDMAN2 View Post
    Thread milling offers several advantages over tapping including that it works on machines which don't support rigid tapping and it gives an identical thread start point on all parts.
    - Nick
    Jul 2008
    70
    Quote Originally Posted by magicniner View Post
    - Nick
    Tapping is faster. I only cut threads when I have no other choice (time is money) With a Hass tapping is crazy fast
    Jul 2011
    13
    The original question wasn't answered. I need to cut a 6 inch NPT thread external. This is a BOBCAD forum. How would one program with BOBCAD to cut pipe threads?
    Apr 2009
    3376
    Quote Originally Posted by AAYoung View Post
    I answered it,,,,,,,draw the spiral and the leads,,,,,,,,,,,,,,,,,,do a search on here,,,I have explained it in detail many times
    Jul 2011
    13
    Searched forum can't find it.
    Drew the tapered spiral, can't put the cutter path to it.
    Apr 2009
    3376
    This is an example I did with 1/2" NPT. If its an internal thread you will need your starting major diameter and your ending major and input all of that into a Spiral CAD feature. Then add your lead in and out. Oh, and the 3D Engrave Feature uses the line as the center of tool so make sure you draw your spiral HALF the diam of your tool smaller then actual.
  1. internal thread milling in D3 plates
    By piridirk in forum Mastercam
    Last Post: 11-03-2015, 06:13 PM
  2. Internal R-thread same as G-thread?
    By myhäje in forum MetalWork Discussion
    Last Post: 06-22-2015, 06:26 PM
  3. 1/4 npt internal thread
    By richcash in forum Material Machining Solutions
    Last Post: 10-20-2011, 11:34 PM
  4. Milling M3x0.5 internal thread - need help
    By MGPL in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 01-09-2011, 09:44 PM
  5. Thread Milling , internal
    By matchy in forum Haas Mills
    Last Post: 09-10-2010, 05:08 AM
