Just wanted to post my solution to have a z-axis prox sensor mounted for homing the Z-Axis (I found that if I didn't retract it high enough during homing, it could hit the gantry brackets, and didn't want to do it manually).
So I went into Fusion360 and designed myself a nice little bracket that mounts on the back side of the Z-Axis carriage, using existing 6 mm holes. It spans three of the holes and rises high enough to cantilever a proximity switch over the top of the Z-axis top plate. I had it 3D printed at Shapeways.com in "Black, Strong and Flexible", basically laser sintered nylon.
Came out perfect and works like a charm! Here the pictures:
